colorful-ant Posted September 5, 2018 Posted September 5, 2018 Yesterday I upgraded from 1.0.4 to 1.0.6 with the new update module. I now had a problem with the urls. I noticed this when I first imported some new products. As a test I manually added products. The problem was that the new products were not displayed and a 404 page appeared. Cache deleted, httaccess regenerated, etc. Older products were displayed in the category. The new products were missing / between the category and the product in the url. Adding manual / in the url also showed a 404 page. By coincidence I have now seen that I have a category in a similar url. - pin-up-retro (Pin-Up & Retro) - rockabilly-pin-up-retro (Rockabilly, Pin-Up & Retro) So far, I have not had any problems with that because they are different. Also in the tool duplicate urls there was no hint. Now I have renamed the one category that the url now looks like this: from "pin-up-retro" (Pin-Up & Retro) to "pin-up-vintage" (Pin-Up & Vintage). edit: The old and the new products were displayed in the category. There were no problems with the older products. Only with the new products appeared after the click a 404-side. When I put my mouse on the products, the correct url was displayed in the browsers at the bottom of the screen (firefox, chrome, etc). edit2: subcategories --> pin-up-retro (Pin-Up & Retro) -> under swimwear rockabilly-pin-up-retro (Rockabilly, Pin-Up & Retro) -> under themes (clothes, skirts etc) edit3: url-format seo options article {category:/}{rewrite}
musicmaster Posted September 6, 2018 Posted September 6, 2018 What happens when you regenerate .htaccess?
colorful-ant Posted September 6, 2018 Author Posted September 6, 2018 @colorful-ant said in similar url - problem since upgrade 1.0.4 to 1.0.6: Cache deleted, httaccess regenerated, etc. ;) no changes - same result :(
Traumflug Posted September 7, 2018 Posted September 7, 2018 Weird. Let's track this: https://github.com/thirtybees/thirtybees/issues/591
Guest Posted September 7, 2018 Posted September 7, 2018 While I don't remember exactly what caused it, I've had this same issue with new products giving 404 on an official Prestashop installation after an update quite a while ago, before I converted to TB. They showed up in categories just like you say. I had to have my more tech-inclined brother fix it for me as I couldn't create new products. (all led to 404)
Traumflug Posted September 8, 2018 Posted September 8, 2018 As much as I try, I can't reproduce this. This brother elaborating a bit on what he did would help a lot.
Guest Posted September 9, 2018 Posted September 9, 2018 @traumflug I sent him a message on facebook and asked but I'm not sure if he will remember. It was well over a year ago. Will update back if he remembers. It is not a TB specific issue though, whatever it was/is.
Guest Posted September 11, 2018 Posted September 11, 2018 Well, I talked to my brother, and while he does remember the issue, sadly neither of us remembers exactly what he did to fix it. Sorry I cannot help you guys with a solution.
