Hey,
I'm interested in making my own module for thirty bees, is there documentation available for that?
Or should I use this page from PrestaShop?
Thanks!
PrestaShop documentation is still mostly right, if one ignores stuff for PS 1.5 and before. And there's this: http://jump-ing.com/traumflugs/writing_modules, very incomplete, still a number of useful tutorials.
Two things: - File config.xml is no longer part of the module, it always gets created on demand now. - Back office modules should get implemented as controllers. Like described here: http://jump-ing.com/traumflugs/backofficemenu_entries Most modules still use their configuration page for their main user interface, which is no longer encouraged.
@traumflug
Hey,
Thanks for your reply. I'm currently following your guide containing information about adding controllers.
But my controller tab still says controller not found.
Here is MyModule.php 'fees.php' in my case ``` <?php if (!defined('TBVERSION_')) exit;
class fees extends Module { const MAIN_CONTROLLER = 'AdminMy';
public function __construct()
    $this->name = 'fees';
    $this->tab = 'front_office_features';
    $this->version = '1.0.0';
    $this->author = 'Stefan';
    $this->need_instance = 0;
    $this->bootstrap = true;
    parent::__construct();
    $this->displayName = $this->l('Fees');
    $this->description = $this->l('Give extra fees to products');
    $this->tb_versions_compliancy = '> 1.0.0';
    $this->ps_versions_compliancy = array('min' => '1.6', 'max' => '1.6.99.99');
 public function install()
    $success = parent::install();
    if ($success) {
        try {
            $tab = new Tab();
            $tab->module      = $this->name;
            $tab->class_name  = static::MAIN_CONTROLLER;
            $tab->id_parent   = Tab::getIdFromClassName('AdminPriceRule');
            $langs = Language::getLanguages();
            foreach ($langs as $lang) {
                $tab->name[$lang['id_lang']] = $this->l('Updater');
            $success = $tab->save();
        } catch (Exception $e) {
            $success = false;
return $success;
} public function uninstall() {
$success = true;
    $tabs = Tab::getCollectionFromModule($this->name);
    foreach ($tabs as $tab) {
        $success = $success && $tab->delete();
    return $success && parent::uninstall();
Here is MyAdminController.php code (and yes I did put in in controllers/admin/AdminMyController.php):
``` <?php if (!defined('TBVERSION_')) { exit; }
class AdminMyController extends ModuleAdminController { public function __construct() { $this->bootstrap = true;
public function initContent()
    $this->page_header_toolbar_title = $this->l('My Controller');
    parent::initContent();
The tab is also named 'Updater' instead of 'My' like the screenshot from your tutorial btw, no idea if that matters though.
Do you perhaps know why it doesn't work?
The controller needs to be in the right place: <module folder>/controllers/admin/. Else the PHP autoloader doesn't find it. And one has to delete cache/class_index.php in the shop installation after placing it. This file will get recreated on the next page request.
If there's something missing in the description, don't hesitate to edit this wiki. Subscription is free and unrestricted, of course.
@traumflug
I've another questions.
Why is in the tab 'Price Rules' my module still called 'Updater'? I can't seem to fix that.
I've changed const MAIN_CONTROLLER = 'AdminMy';
To: const MAIN_CONTROLLER = 'Fees';
And:
$tab->name[$lang['id_lang']] = $this->l('Updater'); To: $tab->name[$lang['id_lang']] = $this->l('Fees');
But it still doesn't change te name? I already cleared the cache and I have deleted class_index.php but without luck.
Thanks!
(Here is all the code again if you need it)
fees.php:
class Fees extends Module { const MAIN_CONTROLLER = 'Fees'; public function __construct() { $this->name = 'fees'; $this->tab = 'front_office_features'; $this->version = '1.0.0'; $this->author = 'Stefan'; $this->need_instance = 0;
    if ($success) {
        try {
            $tab = new Tab();
            $success = false;
return $success;
$success = true;
AdminMyController.php: ``` <?php if (!defined('TBVERSION_')) { exit; }
    $this->page_header_toolbar_title = $this->l('Controller - Fees');
you need to reset the module. The tab is created during module installation --> when you change installation related code, you need to reinstall the module
