Need help - sql query to total stock of all attributes to the product
Chandra
Requesting help from any sql guru:
I am updating the table tbstockavailable from the backend with stocks of various product attributes.
I would like to update the total stock row (attribute=0) of each product with the sum of the attribute stocks.
Is there a single sql query that I can run at the end of attribute updates to update the totals? Thanks.
@Domas Thanks. The row with attribute 0 is the total row for the product.
The pseudocode would be like: For each product, update quantity where product-attribute=0 as sum of quantity of each product-attribute <> 0
I tried this but this isn't right enough: UPDATE tb_stock_available s1 JOIN tb_stock_available s2 ON s1.id_product = s2.id_product SET s1.quantity = (select sum(quantity) from tb_stock_available s2 where s2.id_product = s1.id_product and s2.id_product_attribute <>0) WHERE s1.id_product_attribute = 0
Try this one:
sql UPDATE tb_stock_available s1 SET s1.quantity = IFNULL(( SELECT SUM(quantity) FROM (SELECT * FROM tb_stock_available) s2 WHERE s2.id_product = s1.id_product AND s2.id_shop = s1.id_shop AND s2.id_product_attribute > 0 ), 0) WHERE s1.id_product_attribute = 0
Because mysql do not support updates with subqueries based on the same table, we have to use the hack with inner (SELECT * FROM tb_stock_available). That will results in temporary table. Wonder why mysql won't do that itself...
One important note - previous query will zero out quantities for products without attributes. If you want to keep those intact, use this update:
UPDATE tb_stock_available s1 SET s1.quantity = IFNULL(( SELECT SUM(quantity) FROM (SELECT * FROM tb_stock_available) s2 WHERE s2.id_product = s1.id_product AND s2.id_shop = s1.id_shop AND s2.id_product_attribute > 0 ), s1.quantity) WHERE s1.id_product_attribute = 0
