Hi guys i tried to update to bleeding since 1.0.7 and I got 500 error.
debug mode said this:
No idea what it is the problem.
I only saw in the forum the elastic search bug but I corrected
Any idea?
3 answers to this question
I had a bunch of 500 errors on the BE. Are you using a 3rd party theme?  I think they are doing a lot of work in the themes area of TBs.
I rolled back to 1.08 with no issues.
I asume this is a test site?
No test site but yes, it is a external them.
I localized thanks to @lesley that it was an override.
At the end it was a meta.php
Previously I also had problems with other meta override when I update the theme so I assume it is theme related. I will contact the developer.
What stress having the web down.... :S
