Hi I've encountered a bug when trying to move a product to a different category with CSV import.
(On TB 1.1.0 on local Xampp dev, worked before on 1.08)
In short:
On initial import, the product is assigned to the correct category and this category is set as the default category - which is correct.
The product breadcrumb is also correct: Coffee and Tea -> Tea -> Test Product 1
Bug occurs when I try to do a re-import and change the default category, to Coffee (cat id 4) for example, then the following happens:
Although the product has been moved to the correct category and is listed in the correct category in both the front-end and back-end,
The product breadcrumb incorrectly shows the old path and default category instead of the new one
The default category has changed to Root and not the correct category (Coffee)
If I log in and change the product's default category manually, then the product's breadcrumb changes to the correct category Coffee and Tea -> Coffee -> Test Product 1
From what I recall, this was working in 1.08 where I could re-import the product and move it's category around without any issues. Front-end product breadcrumb would update correctly.
Changing the product categories during subsequent imports make no difference and the front-end still displays the old path and default category of the initial 1st import 😞
Only after changing the default category manually does the new category reflect in the front-end product breadcrumb
Also, I'm not sure why the Home category is not selected if Root (1) is specified...
Images below
How do we fix this? Please help!
Screenshot steps:
CSV for initial category import: 5 (tea / default cat), 3 (Tea and Coffee / Parent Cat), 1 (Root):
Correct default category (though Home appears to be unselected):
Initial import: Breadcrumbs Correct:
CSV to update / change default category to Coffee:4 (coffee / default cat), 3 (Tea and Coffee / Parent Cat), 1 (Root):
Incorrect default category after product import update to change category:
If I manually change the default category to Coffee, then the product breadcrumb updates and displays the category correctly:
Correct product breadcrumb after changing default category manually:
Once again, your help is appreciated in advance. Not sure if I'm doing something wrong?
Acer
In short:
Screenshot steps:
CSV to update / change default category to Coffee: 4 (coffee / default cat), 3 (Tea and Coffee / Parent Cat), 1 (Root):
23 answers to this question
