[Solved][Please help] SEO Rewrite Problem: Trying to add manufacturer to Product route gives 404
Hi
I'm trying to add the manufacturer to the Product route, like so:
{categories}{/:manufacturer:/}{rewrite}
The URL appears to be correct, and the product URL seems to reflect the new URL...
But I keep on getting 404...
What am I doing wrong here?
Your help is appreciated.
ย
Edited by Theo
16 answers to this question
6 minutes ago, piet said:
Maybe clear cache and renew .htaccess will help.
Thanks, I've done this - but no change... (New htaccess, Cleared TB cache, Browser cache = nadda )
7 minutes ago, datakick said:
Try this one:
{categories:/}{manufacturer:/}{rewrite}
Weird, I'm still getting 404... (cleared cache, generated new htaccess)
Am I missing a step? Is there a 're-index' I need to do somewhere?
Have you tried this on your local?
Works fine for me:
However, I'm running on 1.1.x -- so maybe that's the difference. And, of course, if you modified routes for other pages, that can make a difference as well.
21 minutes ago, datakick said:
Works fine for me:
This is odd...
I'm running TB 1.1.0 and haven't made any other SEO Route changes...
If I use {tags} instead of manufacturer - it works. Weird.
But as soon as I use {manufacturer:/} it breaks... Even though the manufacturer exists and the path looks correct in the address bar.
Eeek...
ย
Edited by Theo
I've checked this on a fresh install of TB 1.1.0 as well as an upgraded test install from 1.08 to 1.1.0
And I'm still getting this problem.... seems like it has something to do with {manufacturer:/}
10 minutes ago, piet said:
Are you running your test on Windows or Linux? Maybe there is a difference in configuration.
ย
Windows on Xampp PHP 7.2. However, the URL seems to be correct and the other options {tags}, {reference} seem to work just fine...
Edited by Theo
6 minutes ago, datakick said:
what does your url look like?
it looks like this:
http://localhost/development/local-dev-sites/new-onlinecopiers/coffee-and-tea/tea/bee-hive/tea
17 hours ago, datakick said:
try to apply this fix, hopefully it will solve the issue:ย https://github.com/thirtybees/thirtybees/commit/70f02721bc8ffae1e82c34a1b160ac3aee856cf8
Excellent! This is working, thank you ๐Ÿ™‚
I assume that this patch is included in 30Bz Bleeding Edge (1.1.x+), hence the reason you didn't encounter it in your initial round of testing?
Edited by Theo
Yes, it's part of 1.1.x. But I found and fixed it only after you raised this issue. Thanks for that.ย
Ok cool, no problem ๐Ÿ™‚
Thanks again for the patchย ๐Ÿ‘
ร—
ร—
