Havouza Posted January 27, 2020 Posted January 27, 2020 Hi! Have upgraded to 1.1 Now we get this problem when you want to check out and have bought a product where you must buy a minimum of product. See the screenshot. Default theme.
Havouza Posted January 27, 2020 Author Posted January 27, 2020 Same thing happens when there is a minimum order value set
Havouza Posted January 29, 2020 Author Posted January 29, 2020 It turns out that this only happens to products added. After the update to 1.1 Unfortunately it does not help to downgrade to 1.0.8 again
led24ee Posted January 31, 2020 Posted January 31, 2020 I just tried this and with clean install You can't buy less than minimum. Even if You try to change the amount later in cart then "-" is inactive. I have no idea what happens when You put this minimum up exactly this time when someone put this in cart when there wasn't minimum.
Havouza Posted January 31, 2020 Author Posted January 31, 2020 We solved it by making the product a pack of the minimum amount. And that is really the correct way. Because in all these cases you need to buy either 10 or 20 and so on. Not possible to buy 11. So for now it is not a problem
DRMasterChief Posted January 31, 2020 Posted January 31, 2020 I tried in our testshop, we have an item with a minimum order qty. of 3 (version was 1.08), then upgraded to 1.1.0 (not the standard theme), everything is ok also in the 1.1.0 version, we can not put this item in cart with less than 3, also in cart we can not change to less than 3 (no minus button visible), if we change it by hand to 2 we get a message that we have to buy the minimum qty. of 3 So hmm?! maybe something with your settings or modules? 1
