Havouza Posted June 6, 2020 Posted June 6, 2020 Hi! I have installed and configured the Stripe module. But directly ran into a problem. My country Cyprus is not in the dropdown even if the Stripe homepage state that Cyprus is activated. What can be done? Its a tb modul so someone should know.
Havouza Posted June 6, 2020 Author Posted June 6, 2020 Perhaps @Traumflug or @datakick could have a look and update it. You both seems to have worked with it. Will be much appreciated
Havouza Posted June 6, 2020 Author Posted June 6, 2020 Well looking into the problem, 10 countries is missing so its a quite useless and outdated module. Perhaps it would be a good idea to take it away completely. I for sure will
30knees Posted June 7, 2020 Posted June 7, 2020 (edited) I'm using https://github.com/thirtybees/stripe/releases and it works well. Edited June 7, 2020 by 30knees
Havouza Posted June 7, 2020 Author Posted June 7, 2020 Is that not the same as in the TB 1.1? If it is 10 countries are missing in the dropdown and Stripe support say it must be setup with the country where the business is
