Havouza Posted August 26, 2020 Posted August 26, 2020 Hi! Get this page when changing the order status to order is prepared, Someone have a clue?
datakick Posted August 26, 2020 Posted August 26, 2020 https://www.google.com/search?q=call+to+undefined+function+curl_init()
Traumflug Posted August 27, 2020 Posted August 27, 2020 How disappointing. All the efforts to move thirty bees code to Guzzle, and now this: one of the other dependencies doesn't use it. 1
Havouza Posted August 27, 2020 Author Posted August 27, 2020 6 minutes ago, Traumflug said: How disappointing. All the efforts to move thirty bees code to Guzzle, and now this: one of the other dependencies doesn't use it. Why it suddenly show up. Nothing in software has changed the last 6 month
datakick Posted August 27, 2020 Posted August 27, 2020 That's not software issue, this is server configuration issue. Your server does not have curl library installed
Havouza Posted August 27, 2020 Author Posted August 27, 2020 1 minute ago, datakick said: That's not software issue, this is server configuration issue. Your server does not have curl library installed So you mean it had worked without it for six months? We have changed status a couple of hundred times in that time
datakick Posted August 27, 2020 Posted August 27, 2020 2 minutes ago, Havouza said: So you mean it had worked without it for six months? We have changed status a couple of hundred times in that time There are only few explanations your server settings has changed (maybe you have started using new php version, etc) code never went into this particular branch (pdf generation)
Havouza Posted August 27, 2020 Author Posted August 27, 2020 Nr 1 is we have not Nr 2 its strange if so. But I have now installed curl so we have to see. It was not installed
datakick Posted August 27, 2020 Posted August 27, 2020 10 minutes ago, Havouza said: Nr 2 its strange if so. Well, the issue comes from pdf generation tool. It's possible that you have recently changed order status and it now newly generates invoice. Another possibility is that you have modified pdf templates, and added reference to remote image.
