Roberto G Posted September 18, 2020 Posted September 18, 2020 Error trying to install Cookiebot module in Prestashop 1.7.6.7. Installing module from BO - Manage Modules never ends even if you try to interrupt the installation, you have to abandon the site. Login in again to BO and try to open Manage Modules it doesn't display anything, the only way to recover MM is deleting cookiebot folder from modules. Can you help me, please? Thanks,
haylau Posted September 18, 2020 Posted September 18, 2020 You might want to ask the question on the Prestashop forum, this is ThirtyBees
Roberto G Posted September 18, 2020 Author Posted September 18, 2020 2 minutes ago, haylau said: You might want to ask the question on the Prestashop forum, this is ThirtyBees Thank you for your answer. I downloaded this module with you so i thought you can help me.
haylau Posted September 18, 2020 Posted September 18, 2020 Thirtybees is based on Prestashop 1.6 it is unlikely modules will work on Prestashop 1.7
cienislaw Posted September 19, 2020 Posted September 19, 2020 9 hours ago, Roberto G said: Thank you for your answer. I downloaded this module with you so i thought you can help me. https://store.thirtybees.com/shop-modules/front-office/cookiebot there is nothing on the module page mentioning Prestashop in any version.
Traumflug Posted September 19, 2020 Posted September 19, 2020 That's true. None of the modules provided by thirty bees are made for PS 1.7. Some happen to work on PS 1.6, which is more by chance than by intention. As @haylau said, this is thirty bees.
