I have some trouble with updates of modules and shop. I tried to update a clone of my shop to a bleeding edge version to try the new geolocation module I'm in dire need of 😉 I'm currently on 1.1.0. But updating the shop or modules doesn't seem to work anymore so to test this further I also installed fresh copies of 1.0.8 and 1.1.0 but it's everywhere the same for some month now. Updating isn't possible anymore. Here you can find some probably related errors.
Fresh Shop Installations succeed with following errors (TB V 1.0.8 & 1.1.0)
An error occurred during installation...
This is a non-fatal error. It can be fixed in Backoffice later. Just jot it down or make a screenshot to not forget it now, or look it up in logs/ later.
Translations for English (English) and thirty bees version 1.0.8 not found.
Translations for thirty bees version 1.0.7 not found either.
Translations for English (English) not installed.
No translations pack available for your version.
Translations for Deutsch (German) and thirty bees version 1.0.8 not found.
Translations for Deutsch (German) not installed.
Happens with 1.0.8 and 1.1.0 ofc with 1.1.0 the version numbers are different. Back in time when switching to TB I never ever had any installation problems, warnings or errors.
Shop Update with Core Updater
So I thought I read somewhere that the issue for the maxmind module is 823 so i chose this issue and clicked compare in the core updater. Comparison sometimes works, most of the time the first time it doesn't and shows below error. Also if it does work the same error also appeares everytime when clicking on update.
I cannot update modules for some time now. There's no error messages in debug mode.
Steps and what they lead to (all in backend->modules):
Doing module update:
bootstrap success-message appears that says it's been updated, but version still the same and the module in the module list still shows the update button instead of configure or whatever.
Uploading and installing a module zip file via the backend interface, if it's an update or doesn't exist yet:
Works like a charm, it uploads it, unzips it, installs it, i can configure it, everything good. So all this doesn't look like folder/file permission problems. I installed some birthday module and the latest core updater version without problems.
Problems exist with all core updater versions.
Conclusion
Seems like it's server related or a bug. Maybe it's got problems retrieving stuff from the git repository, downloads broken packages even or there's some bug in unzipping the package? Because sometimes comparing works and sometimes is says there's a js problem while using the same issue as comparison. I think wakabayashi already said everythings running fine for him so maybe there's really some server settings that need to be adjusted. What makes me believe more in a server settings issue is that 1.0.8 for sure was working fine until I switched to 1.1.0 and this version updated fine as well in the beginning if I remember correctly. And I updated quite a lot of modules without any problems. And now fresh installations of 1.0.8 and 1.1.0 all have the same problems. So this leads me to believe that some server settings have been changed. I'll also ask my hoster if there was any server related updates, but as I can't remember how long this problem exists, it might be hard to pin point a guilty one 🙂 If someone has an idea what could be responsible here please share 😄
What it also cannot load is bootstrap-sortable:
Error:The resource from “https://raw.githubusercontent.com/drvic10k/bootstrap-sortable/1.11.2/Scripts/bootstrap-sortable.js” was blocked due to MIME type (“text/plain”) mismatch (X-Content-Type-Options: nosniff). en
... but I think that's not related? Strange though as I have set the mime type for js as application/javascript on my server so not sure where this text/plain comes from... Or should I set my servers mime definition to text/plain? But that wouldn't be so good I think?^^
oliiix
logs/
later.Happens with 1.0.8 and 1.1.0 ofc with 1.1.0 the version numbers are different. Back in time when switching to TB I never ever had any installation problems, warnings or errors.
Error: Request to https://www.domain.tld/shop/admin/index.…51b83a&action=processUpdate&ajax=1 failed with status 'rejected'. controller.js:210:13
Modules
3 errors
- thirty bees Updater: There was an error while extracting the module file (file may be corrupted).
- Module not found
- Module Block Links cannot be upgraded: Error while extracting the latest version.
Conclusion
Error: The resource from “https://raw.githubusercontent.com/drvic10k/bootstrap-sortable/1.11.2/Scripts/bootstrap-sortable.js” was blocked due to MIME type (“text/plain”) mismatch (X-Content-Type-Options: nosniff). en
System: Apache 2.4, PHP 7.1
Thanks a lot!
Oli
Edited by oliiix4 answers to this question
