Hi,
I have installed a module that displays a map when selecting a shipping method to show a map and select a pickup place.
The module seems to work with PS 1.6, but in TB there are errors that stop the module from loading the map.
This is what the module support tells me (I will translate):
Could be an outdated jQuery library
This is the screenshot of the error
It seems there are 2 posible solutions
Once is to review if in the file classes/controllers/AdminController.php there is a call to Query ($this->addJquery();) and if in the file controller.php there is the function:
public function addJquery($version = null, $folder = null, $minifier = true)
$this->addJS(Media::getJqueryPath($version, $folder, $minifier));
The other would be to update the content of the directories Admin y js.
The best solution is to contact TB developpers.
(Translation finished)
Any ideas?
@toplakd could be because of the 3 steps modifications?
Regards
You can always try that PS module in stock Thirty bees install (without any modifications).
To see if it works or not.
And than go from there.
Based on the screen shot it might be 2 things.
  1. you installed a ps 1.7 version of that module (the filename is font17.js?)
  2. the js file from the module is looking for some variable/object named prestashop.
I will try when I had some time (i need a bigger server because I do not have enough space in mine)
1. I checked it and it is 1.6 version.
2. could be, I will ask the developper.
