MailAlert seem not work correctly
Hello,
when product stock is updated, The mailalert_customer_oos table is updated (customer mail was remove) but no mail is send.
Before start debugging someone can tell me if the module works correctly?
I'm TB 1.1.10 - 1.1.X on php 7.4
4 answers to this question
I had a similar problem and it turns out that the modified theme I was using did not have the directory modules\mailalerts with the mail files, translations and views.  Once I copied the files from the previous theme I was using, everything worked fine.
using 1.1.x bleeding edge with PHP 7.3.2 and Modified Community Theme
Edited by Rhapsody
