I'm trying to use Tidy to clean up a few hundred thousand abandoned carts. It seemed to work fine when I was on TB 1.2 but now with TB 1.3 I am getting 500 errors. I don't know if that is because of the upgrade or because I moved the site to a different server and need to increase something in php.ini
Anyway -- I turned on debug in defines.inc.php and the error I am getting is that my database does not have the table ps_pagenotfound
I've confirmed that is true by checking the database directly.
Is that normal?
I've been having a lot of issues with this store for months and am very close to getting it to work properly so I'm sensitive to anything that could be wrong.
Edited by Naldinho
1 hour ago, toplakd said:
Go to Core Updater and click on Database icon on top right.
Apply the fixes.
When I did this I got a really long list -- ~30 labeled Critical and ~100 labeled Recommended. Around a third also have the Dangerous tag.
Is that normal?
I'm going to apply all the fixes and see what happens.
After applying fix manually I would say those numbers were low -- it was likely double or more.
Everything is fixed except the following three
