This is my first Thirty Bees post. I've arrived here as once again my ISP is forcing me to move to PHP 7.4 and a move to Thirty Bees was suggested by someone in the Prestashop forum - rather than continually trying to manually fix 1.6.24.
So I'm trying a migration from my Prestashop installation to ThirtyBees and I've set up a test site to try this on. This is running PHP 7.4.
I've got as far as installing TB 1.0.8 following the migration guidelines. On running the Core Updater to move the installation
on to TB 1.3 I get the 'You have local changes' message ( attached ). However there's nothing under the headings
'Changed Files', 'Missing Files', 'Extra Files' so I'm not sure which are the problem files.
Confession - my version of Prestashop 1.6.24 was created from the released version and modified to work under PHP 7.2 by manually incorporating the mods from GITHUB to make 1.6.24 PHP 7.2 compatible - https://github.com/PrestaShop/PrestaShop-1.6/pull/4
It looks like these mods were going to be incorporated into a 1.6.25 release which never happened.
Is this what's causing the Core Updater message?
Should I revert to a 'vanilla' 1.6.24 and do the migration again?
If I simply reinstated the changed files ( which I saved before updating ) would this be enough for TB Core Updater to work?
Ian Ashton
7 answers to this question
