Ian Ashton Posted August 23, 2023 Posted August 23, 2023 When creating a pack of existing products I get a Quantities (500 error) on clicking Save and Stay. See attached file. I can do this on my local server and get the failure when running at my ISP ( Fasthosts in the UK ) Checked the error log on the server and found an error ( see attached file ) which relates to a disabled function 'set_time_limit'. I assume this is a restriction set by my ISP but not sure if there's a workaround? This is the only time I've come across this error. Anyone any ideas? Thirty bees version: 1.4.0 PHP Build 8.0 MySQL 5.6.51
datakick Posted August 23, 2023 Posted August 23, 2023 I believe this is causes by some module. There are only a few places in the core that call this function, and none of them is in the product controller area. Anyway, a lot of modules (for example modules to synchronize data or that generate feeds) uses on this function, because default 30seconds might not be enough. If your hosting provider can't disable this, I would consider changing server.
Ian Ashton Posted August 31, 2023 Author Posted August 31, 2023 FWIW - after more investigation 1. Creating/editing a pack worked with Thirtybees 1.4/PHP 7.4 2. Creating a pack fails on Thirtybees 1.4/PHP 8.0 (see original post) system errorlog message [Thu Aug 31 12:15:06.678767 2023] [fcgid:warn] [pid 98599] [client 2.126.60.141:62483] mod_fcgid: stderr: Tried to use set_time_limit which is a disabled function, this is not allowed., referer: https://ashtonjones.uk/index.php exception log in Thirtybees log folder *ERROR* 2023/08/31 - 12:16:18: Error: Cannot use positional argument after named argument at line 665 in file classes/stock/Warehouse.php 3. Creating a pack of products with products NOT in advanced stack control works. As I'm running a system I ported over from Prestashop 1.6.24 I'm wondering if I'm looking at a Thirtybees problem or one that's specific to my service? So - setup test system from virgin 1.4 release and test data ( on a raspberry pi !! ) edited product to move them to Advanced Stock Management and created a pack. Seemed to work OK but as soon as I add the pack to my default warehouse I get the on screen error on clicking SAVE.
datakick Posted August 31, 2023 Posted August 31, 2023 Looks like PHP8 issue. Try to edit file /classes/stock/Warehouse.php line 665, and change $res = call_user_func_array('array_intersect', $list); to $res = call_user_func_array('array_intersect', array_values($list)); Let me know if that helped -- if so, I will add this to bleeding edge.
Ian Ashton Posted August 31, 2023 Author Posted August 31, 2023 Thanks for looking at this. The fix worked on the virgin install (on my local server) and on my online test service.
nickz Posted August 31, 2023 Posted August 31, 2023 I found that TB 1.3 works smoother on PHP7.4 Locally I had severall crashes on TB 1.4 Linux and Windows alike. We run pretty old hardware though.
