SakuraKitKats Posted October 14, 2024 Posted October 14, 2024 I am using the default Niara theme and have the problem that Google only takes the images from Niara_cart, therefore all images are 80x80 in size which leads to all my products being rejected in the Merchant Center. Even in search results the pictures are very tiny. I would want the pictures to be Niara_large (458x458) I have attached an example image of my problem. Anything I can do to fix this?
datakick Posted October 15, 2024 Posted October 15, 2024 Use sitemap module, and configure it to use proper image variants: Add your sitemap to your google console, and wait for google to reindex.
SakuraKitKats Posted October 15, 2024 Author Posted October 15, 2024 1 hour ago, datakick said: Use sitemap module, and configure it to use proper image variants: Add your sitemap to your google console, and wait for google to reindex. Thank you, this will fix the index problem. As for Google Merchant Center, is there any module to export my catalog to it?
wakabayashi Posted October 15, 2024 Posted October 15, 2024 1 hour ago, datakick said: Use sitemap module, and configure it to use proper image variants: Add your sitemap to your google console, and wait for google to reindex. It's very funny, that I looked at this a week ago and noticed, that it's not possible to select the original source image. @datakick do you think that would be a sensible enhancement? If yes, I could make a PR sooner or later.
datakick Posted October 15, 2024 Posted October 15, 2024 16 minutes ago, wakabayashi said: It's very funny, that I looked at this a week ago and noticed, that it's not possible to select the original source image. @datakick do you think that would be a sensible enhancement? If yes, I could make a PR sooner or later. I'm afraid that would not work properly with watermark module. 1
datakick Posted October 15, 2024 Posted October 15, 2024 29 minutes ago, SakuraKitKats said: As for Google Merchant Center, is there any module to export my catalog to it? I'm sure there are many. My datakick module can be used to generate xml feed for GMC. You can use channable module to export your content to channable, and from there you can push it to any number of third party services, including GMC. there is google shopping flux free module (https://github.com/d1m007/gshoppingflux) - there is some compatbility issue with thirty bees, see this PR: https://github.com/d1m007/gshoppingflux/pull/105/files and I'm sure there are many more 1
