Havouza Posted February 18 Posted February 18 We run the latest version of TB. It rund php7.4 because it seems there is some modules that cant handle php8. It seems that the Theme is the problem. I know there is no TB themes but before PS themes worked. Now PS has no 1.6 themes anymore and I assume 1.7 and 8.x does not work. Am I correct?
waylonwesley Posted February 18 Posted February 18 17 minutes ago, Havouza said: We run the latest version of TB. It rund php7.4 because it seems there is some modules that cant handle php8. It seems that the Theme is the problem. I know there is no TB themes but before PS themes worked. Now PS has no 1.6 themes anymore and I assume 1.7 and 8.x does not work. Am I correct? sprunki Some older themes and modules may not be fully compatible with PHP 8, which is a common situation during transitions to newer PHP versions. 1.6 themes are no longer available, and it’s probable that themes from versions 1.7 and 8.x will also not work with your setup.
Havouza Posted February 18 Author Posted February 18 Everything we use in modules manage php 8, its just the theme that don't. As I read your answer PS 1.7 and 8.x themes can work with TB?
the.rampage.rado Posted February 18 Posted February 18 If you already have a theme that you like I would advise to contact datakick and he might have some free time in order to help you out with any bugs that you have. The main issue is always within theme's block cart overrides - which leads to 500. The rest is most probably warnings and deprecations. I'm with Warehouse 3.8.7 (the latest version for PS1.6) and it had some issues, cart one too - but now I'm rocking it on php 8.1 with few warnings and it's making me money. Same - I would like to contact datakick soon in order to work on those issues so I can move to 8.2 and later 8.3 (if nothing big pops up).
nickz Posted February 18 Posted February 18 Leo themes https://www.leotheme.com/prestashop/themes.html Envato themes https://themeforest.net/search/prestashop 1.6 and there are more. You also can modify NIARA to almost anything you like.
Havouza Posted February 18 Author Posted February 18 18 minutes ago, nickz said: Leo themes https://www.leotheme.com/prestashop/themes.html Envato themes https://themeforest.net/search/prestashop 1.6 and there are more. You also can modify NIARA to almost anything you like. Have looked thru them. Problem is that not one of them state what php version they support
x97wehner Posted February 18 Posted February 18 I'm on Warehouse on PHP 8.2 after some manual work to update. Not sure you'll be able to get it anymore though. I believe Panda is likely the most flexible theme available that is mostly configuration and not coding if that's what you're looking for https://www.sunnytoo.com/product/panda-creative-responsive-prestashop-theme . I'm not sure on their PHP compatibility but I remember them being quick to respond when asked. I believe I last tested it on 8.1 and it worked.  1
hitillness Posted April 10 Posted April 10 On 2/18/2025 at 3:23 PM, Havouza said: We run the latest version of TB. It rund php7.4 because it seems there is some modules that cant handle php8. It seems that the Theme is the problem. I know there is no TB themes but before PS themes worked. Now PS has no 1.6 themes anymore and I assume 1.7 and 8.x does not work. Am I correct? You're mostly right—PS 1.7 and 8.x themes aren't directly compatible with TB. TB is closer to PS 1.6, so older themes work better. Some PS 1.7 themes might work with heavy tweaking.
Havouza Posted April 10 Author Posted April 10 Yea I know and 1.6 themes are only very few nowadays. PS dont have them anymore
nickz Posted April 11 Posted April 11 There are more than enough. You can mod themes and mobil most look like an egg to another,
