ahhh, you want to use an image for your SSL protection and possibly payment logos in the header.
use the banner module if you are not already using it. replace the code and use images float left etc
As always, first create your own manual backup before each upgrade. if something unexpected happens. It is best to try a copy of the shop first.
disable the option to create backup. then it should work.
von ps weiß ich das es ein brauchbares modul gibt - programmiert von silbersaiten
https://www.silbersaiten.de/prestashop/de/prestashop-module/244-dhl-intraship-connector.html
mit tb noch nicht probiert, sollte evtl auch funktionieren
bo -> product -> combinations
you can also use the "product combination generator" in order to automatically create a set of combinations.
its a little bit faster to creat, if you have all attributes in your list - or better import with csv
für interessierte - vom händlerbund gibt es eine 3-teilige info - ob man durch diese info schlauer wird, naja ....
https://www.onlinehaendler-news.de/recht/rechtsfragen/32557-geoblocking-verordnung-teil-3-vertragsfreiheit.html?utmsource=Newsletter&utmmedium=Link&utm_campaign=Weekly
migration from ps to tb.
debug mode off - it does not bother me as it seems to work. the mails are sent normally and arrive at the customers. I noticed it only by accident, when I forgot to put the debug mod off again.
it seems like the table is not correct.
psaeucemail - structure
32 entries
I had previously activated the debug mode because of a problem and forgot to disable it again.
When I just wanted to answer a customer support request, I received the following message:
I do not know if this info is helpful
tb 1.0.7
war seit langer zeit mal wieder im ps-forum unterwegs und bin auf eine diskussion gem. themen-titel gestoßen.
evtl möchte hier auch jemand dazu fragen stellen oder antworten hinterlassen.
https://www.prestashop.com/forums/topic/907190-3122018-neue-eu-verordnung-anti-geoblocking/
hmmm, just by chance I just looked at the sales list in Prestools.
There, the products are listed with variants. The period is adjustable and can be sorted by clicking on the respective column heading. (Click twice - for a sort from large to small) ;)
I hope it helps a little bit in the beginning.
very interesting topic
I do not know how your variants etc of the products are constructed. in the statistics module or view "statsforecast" is at the end of the list of sold variants.
When I look at the list with me, I also have no revealing results.
At the moment I have other important things to do, but I will put it on my list. Maybe I can do something in the next few months or someone else is faster.
