When you want to change the short description field in multistore you set the top bar on yes. This does not make it possible to edit the product title. But when ticking the checkbox before the title off and on again it becomes totally impossible as youn cant put the cursor there anymore. The field blinks and then becomes in active.
Smile
11 answers to this question
