Block Categories in Footer
Am I missing something
I want to list our store top level categories in the footer. I have enabled the module, and selected 4 columns so they are spread across the page. But they are still showing as one column (not a cache issue). Any ideas? (Panda Theme)
7 answers to this question
1. Replace this code $this->smarty->assign('numberColumn', $numberColumn); in the \modules\blockcategories\blockcategories.php file with $this->smarty->assign('numberColumn', $nbrColumns);
2. Replace the \themes\panda\modules\blockcategories\blockcategories_footer.tpl file with the one in the attachment, see the pic below, I've highlighted all changes out.
Yes, looked at those but I would have to manually add each category and manually update as and when. The block categories should be automatic
That setting was deprecated for a very long time, even the TB's community theme doesn't use it any more. I you do need it  I can guide you to do some changes to the \modules\blockcategories\blockcategories.php and the \themes\panda\modules\blockcategories\blockcategories_footer.tpl to make it work.
Edited by Jonny
Same question for Niara theme - does anyone know if I should adapt the instructions above?
I am on TB version 1.1#905 - does anyone know if this is fixed in later versions?
