TB1.1.0 BO Product edit - JS Error: displayPrice is not defined.
Hello,
On my local TB, on FIREFOX, When i try to edit price on product. the price tab content is empty. All saves buttons from all tab are disable with the loading animation.
JS console tell me:
the displayPrice function is in:
https://github.com/thirtybees/thirtybees/blob/1.1.x/js/tools.js#L90,
and it call  from:
https://github.com/thirtybees/thirtybees/blob/1.1.x/js/admin/price.js#L152
All Works fine when I disable firefox cache.
Do you experiment the same problem?
3 answers to this question
Does it continue to work if you turn the cache back on? Or don't turn it off, just reload the page using the reload button? It might be a stale tools.js, which would be a one-time problem.
