AndyC Posted September 13, 2019 Posted September 13, 2019 Hi I can't really find any real information about "manufacturer" tab under accessories , Can anyone enlighten me on the use of this Like does it help in SEO mostly and if yes is there a way to get it to show on the product page , don't really want a image just the name tia
colorful-ant Posted September 13, 2019 Posted September 13, 2019 if you use panda theme go to "stthemeeditor" - tab "product pages" here you can change the settings - manufacturer and product page
AndyC Posted September 13, 2019 Author Posted September 13, 2019 Thanks ..I was looking for manufacturer.. Thought brand was something else as when I used it all I got was the default image . Although I do need to move it up a bit if at all possible Get a error page when I tried with this .. I may have taken to much {if ($show_brand_logo>1 && $product_manufacturer->id_manufacturer) || (isset($sttheme.display_pro_tags) && $sttheme.display_pro_tags>1 && isset($product->tags[$cookie->id_lang]) && count($product->tags[$cookie->id_lang]))} <div class="product_extra_info_wrap"> {if $show_brand_logo>1 && $product_manufacturer->id_manufacturer} <p id="product_manufacturer_info" class="product_extra_info clearfix"> <span class="product_extra_info_label">{l s='Brand:'} </span> <a {if $enable_google_rich_snippets} itemprop="brand" itemscope="" itemtype="https://schema.org/Organization" {/if} href="{$link->getmanufacturerLink($product_manufacturer->id_manufacturer, $product_manufacturer->link_rewrite)}" title="{l s='All products of this manufacturer'}" target="_top"> {if $enable_google_rich_snippets}<meta itemprop="name" content="{$product_manufacturer->name}" />{/if} {if $show_brand_logo==2} {$product_manufacturer->name} {else} <img {if $enable_google_rich_snippets} itemprop="image" {/if} alt="{$product_manufacturer->name}" class="replace-2x" src="{$img_manu_dir}{$product_manufacturer->id_manufacturer}-manufacturer_default.jpg" /> {/if} </a> </p>
Occam Posted September 14, 2019 Posted September 14, 2019 If $show_brand_logo is boolean which I assume, it can only be 0 (deactivated) or 1 (activated). So if $show_brand_logo > 1 makes no sense and must therefor cause an error. 1
shoptechmedia Posted September 20, 2019 Posted September 20, 2019 On 9/15/2019 at 1:32 AM, Occam said: If $show_brand_logo is boolean which I assume, it can only be 0 (deactivated) or 1 (activated). So if $show_brand_logo > 1 makes no sense and must therefor cause an error. I was about to laugh actually when I saw the code.. lol..
