No attributes for virtual products/services
  • Answers 57
  • Created
  • Last Reply
Top Posters For This Question
Yes, it's defined. It's _DB_PREFIX_, defined in config/settings.inc.php. PrestaShop has the same definition, so no excuses to not use this definition properly :-)
But then it must be crap coding, because when it crashes it does it because the sql is pscombinationdownload ......... That table does dot exist because it is created as tb_comb....... and so on
OK. Now I will add some more mystery on the table. Just to be sure when I contacted the developer I installed a fresh PS 1.6.1.11. During installation I changed the Db prefix to tb_. But after installing the module it worked flawlessly also with the Db prefix as it should do. But why not the other way round
So to conclude. The module brake the tbshop if the DBPREFIX is tb_. A tb-shop with ps_ prefix works without a problem. A PS shop works without a problem with both prefixes Suggestions anyone?
@Havouza said in No attributes for virtual products/services:
I think this should be put in bug reports because if the db_prefix doesn't work, it may also not work with other modules.
I will first hear what the developer say. I am sure it a module problem. I have found a couple of others that is in the PS shop also
Just got back at the office, you guys are working on weekends ? ;-)
Please let me know what the dev says, i'm very anxious to give this a try :-)
Thanks ! Great find !
It is no problems anymore. works perfect. My test shop crashed the first time but it must have been some other reason. I restored it and installed the module again without problem
I've just tried to install it but it crashed at first then the second time I got this:
Parse error: syntax error, unexpected '{', expecting function (T_FUNCTION) in /Applications/XAMPP/xamppfiles/htdocs/tbquebecamerique/classes/module/Module.php(1859) : eval()'d code on line 22 [PrestaShopException]
Class ProductOverrideOriginal_remove593e9ebf16602 does not exist at line 1860 in file classes/module/Module.php
It's only my desktop dev installation no worries.
I know why.. it is because I had some of the same files already in the override folder and it breaks it, can't install if files are there already. Renamed mine and I could install.. but now i cant log to update it, says this domain is already associated with another account :-/
