Hi
Under orders tab when I go to print out either a Invoice or Delivery Slip on a order I end up with with the wrong country under my Shop Name.. I did a quick google search and there was 1 that said put the country under Contact details.
But hasn't made a difference , it still says United States..
Any other ideas as to how I can get it to say United Kingdom
Using Latest Version and Panda 1.5.1
Edited by AndyC
It is a PDF .. It's the delivery note image I've added. I don't use invoice as the customer can do it themselves if they need to
Ok maybe my words were not 100% clear. But come one, you have almost 600 posts, you should know, what was meant 😉
To end this puzzle: for themes/panda/pdf/delivery-slip.tpl
Yeah sure
* 2007-2016 PrestaShop
* NOTICE OF LICENSE
* This source file is subject to the Academic Free License (AFL 3.0)
* that is bundled with this package in the file LICENSE.txt.
* It is also available through the world-wide-web at this URL:
* http://opensource.org/licenses/afl-3.0.php
* If you did not receive a copy of the license and are unable to
* obtain it through the world-wide-web, please send an email
* to [email protected] so we can send you a copy immediately.
* DISCLAIMER
* Do not edit or add to this file if you wish to upgrade PrestaShop to newer
* versions in the future. If you wish to customize PrestaShop for your
* needs please refer to http://www.prestashop.com for more information.
*  @author PrestaShop SA <[email protected]>
*  @copyright  2007-2016 PrestaShop SA
*  @license    http://opensource.org/licenses/afl-3.0.php Academic Free License (AFL 3.0)
*  International Registered Trademark & Property of PrestaShop SA
{$style_tab}
<table width="100%" id="body" border="0" cellpadding="0" cellspacing="0" style="margin:0;">
    <!-- Addresses -->
    <tr>
        <td colspan="12">
        {$addresses_tab}
        </td>
    </tr>
    <tr>
        <td colspan="12" height="30">&nbsp;</td>
    </tr>
    <tr>
        <td colspan="12">
        {$summary_tab}
        </td>
    </tr>
    <tr>
        <td colspan="12" height="20">&nbsp;</td>
    </tr>
    <!-- Products -->
    <tr>
        <td colspan="12">
        {$product_tab}
        </td>
    </tr>
    <tr>
    </tr>
    <tr>
        <td colspan="7" class="left">
            {$payment_tab}
        </td>
        <td colspan="5">&nbsp;</td>
    </tr>
    <!-- Hook -->
    {if isset($HOOK_DISPLAY_PDF)}
    <tr>
    </tr>
    <tr>
        <td colspan="2">&nbsp;</td>
        <td colspan="10">
            {$HOOK_DISPLAY_PDF}
        </td>
    </tr>
    {/if}
</table>
I do have Store Contacts ..Is that it ... I've filled it all in with my correct address etc ,as a google search said that could be a issue.
Weird thing is it was working fine up until December. So between then and now something has changed
It also seems to have changed format as before it has the address twice on the top ,now only once
Edited by AndyC
im not sure, but check your basic pdf folder and files
if you have changed some files ....
themes/webpoint/pdf/delivery-slip.tpl (replace webpoint by your theme/panda)
missing a ...tpl file
example:
And with that I have found the issue ...Went back though everything I had done in the past couple of weeks .... It's a module "Super Abandon Cart"...Been UN-installed.
Another thing ticked off my list ... Now just have to work on the chex module
Although would still like to remove the Billing Address but it ain't that important
Thanks again for trying to help
Edited by AndyC
you can try, to change your (some) ....adresses(-tab).tpl -> root folder /pdf
i have not tested
$invoice_address
$delivery_address
original file
358387865_Screenshot_2020-01-27Dateihttpdocspdfdelivery-slipaddresses-tabtplanzeigen.png.565bc583e61505be0d7a000ae47d49b2.png
Edited by colorful-ant
Thanks ,I'm going to leave it as it is for now.. Got more important things to worry about lolol ..Payments being the next thing and chex module
  • 2 weeks later...
