movieseals Posted February 9, 2020 Share Posted February 9, 2020 Hi! I am having an issue right now with the sitemap module. Whenever I try to generate a sitemap, either by cronjob or manually, the module times out after roughly 20 seconds. I checked the php ini, I have plenty of memory, max execution time is pretty high, and most other long scripts usually run fine on the site so I am at a loss as to why this is happening with this particular module. Link to comment Share on other sites More sharing options...
AndyC Posted February 9, 2020 Share Posted February 9, 2020 Which hosting you with ... Link to comment Share on other sites More sharing options...
datakick Posted February 9, 2020 Share Posted February 9, 2020 Hard to tell what the problem is, there isn't any resource limitations in the module itself. But it can be caused by other modules -- I've seen modules that set php max exec time to 20 secs, and never restore it after their job is done -- things like this can affect other modules in pipeline 1 Link to comment Share on other sites More sharing options...
movieseals Posted February 9, 2020 Author Share Posted February 9, 2020 I will try with all but TB modules disabled to try and pinpoint if it is a module. Thanks. Link to comment Share on other sites More sharing options...
