Chris1d Posted June 28, 2020 Share Posted June 28, 2020 I'm having real trouble with my backoffice not showing the correct stats. I'm getting lots of visitors to the site, but on the dashboard section "Most viewed" I only get 1 view per product. I know more than 1 person has looked at it (had people test it) but the dashboard still just shows one view the entire time period (month) Any suggestions? Link to comment Share on other sites More sharing options...
Traumflug Posted June 29, 2020 Share Posted June 29, 2020 Did you turn off demo mode? There's a switch in the upper right corner on the back office start page. Link to comment Share on other sites More sharing options...
Chris1d Posted June 29, 2020 Author Share Posted June 29, 2020 11 minutes ago, Traumflug said: Did you turn off demo mode? There's a switch in the upper right corner on the back office start page. Yes Demo mode is off. Link to comment Share on other sites More sharing options...
AndyC Posted June 30, 2020 Share Posted June 30, 2020 Mine never seemed to work either , so just removed them , all I have are orders showing. I get the same info from my analytic's Link to comment Share on other sites More sharing options...
SLiCK_303 Posted June 30, 2020 Share Posted June 30, 2020 uninstall/delete/install all affected BO modules....? Link to comment Share on other sites More sharing options...
Chris1d Posted July 4, 2020 Author Share Posted July 4, 2020 Yes I've also tried that I believe. Link to comment Share on other sites More sharing options...
