x97wehner Posted October 23, 2020 Posted October 23, 2020 Wondering how to make the newsletter box default to checked in the Chex module at checkout. I'm not in a GDPR country so need this to function this way. Can someone advise how to make this happen? maybe @datakick
AndyC Posted October 26, 2020 Posted October 26, 2020 Hi .. I had mine permanently ticked, but not sure how I did it lol, I've just removed it as never seemed to send emails
datakick Posted October 26, 2020 Posted October 26, 2020 Default values for fields are not supported at the moment, they will be in the next version. Also - if you have visitors from EU then your site have to be GDPR compliant. The fact that you are from non-eu country does not absolve you from the responsibility. Granted, you will probably never be sued or fined, but you could be.
x97wehner Posted October 26, 2020 Author Posted October 26, 2020 (edited) 3 hours ago, datakick said: Default values for fields are not supported at the moment, they will be in the next version. Also - if you have visitors from EU then your site have to be GDPR compliant. The fact that you are from non-eu country does not absolve you from the responsibility. Granted, you will probably never be sued or fined, but you could be. Yeah, I'm quite familiar with GDPR regulations. It doesn't apply to our business so we have adopted an opt-out model for that reason. We just need the software to support it. Glad to hear about the update in next release. Edited October 26, 2020 by x97wehner
