RonGin Posted November 17, 2020 Posted November 17, 2020 Can you tell me how to fix this in the stats: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'in,SUM(IF(o.id_lang = 3, total_paid_tax_excl / o.conversion_rate, 0)) as hi,SUM(' at line 1 in file modules/statsmodule/stats/statsforecast.php at line 632
wakabayashi Posted November 17, 2020 Posted November 17, 2020 Please enable debug mode and post the full error message.
wakabayashi Posted November 17, 2020 Posted November 17, 2020 Btw this is an official module and I have never seen it before. Is this module up do date? When do you get this message exactly?
RonGin Posted November 17, 2020 Author Posted November 17, 2020 (edited) This is in the dashboard where the visitor link are. I have been getting since I made my move from A2 to hostgator for the last 30 days. Yes the cart is up to date 1.1.0 version. Edited November 17, 2020 by RonGin
datakick Posted November 17, 2020 Posted November 17, 2020 You have Indian language enabled in your store, don't you? The stats module contains a bug that only reproduce for this language, because its iso code is 'in'... and that is reserved sql keyword.
RonGin Posted November 17, 2020 Author Posted November 17, 2020 Hello, Datakick that is the problem I removed and it is working fine. Thank you very much. Ron
