Hi,
How does the Use SSL option actually work?
I had it disabled and the backoffice links I could click on were still prefixed by https://
Which "internal" links does that actually apply to? I noticed that if I force https redirections with `RedirectMatch 301 ^(?!/\.well-known/acme-challenge/).* https://example.com$0` while the option is off I get in a infinite loop situation.
8 answers to this question
  On 11/27/2021 at 10:12 AM, musicmaster said:
What you saw is most likely a result of the auto-complete function of your browser.
Expand
I don't think browsers do that. I hover with the mouse pointer over some links in the back office side panel and the status bar shows these links beginning with https://
I looked at the thirty bees code and I unfortunately don't understand that well. It seems to me that the option toggles the use of https:// but I don't understand to what links it applies to.
The back office uses relative links. If you access it via https all links will point relatively to https. If you access it via http all links will relatively point to http. A few versions ago chrome made it harder to access things by http. and hides the www sub domain and also the protocol by default.
I appreciate your replies but my question is more specific to how the `Use SSL` option works.
I am not trying to debug anything, I just want to understand what that option actually does. As I said, I looked into the code of thirty bees and I noticed that it makes URI begin with https:// however I can't understand which URI it applies to.
Expand
It applies to all absolute url generated by thirty bees core. Links to controllers, modules, images, css and javascript assets,... what have you
