Pedalman Posted October 11, 2024 Posted October 11, 2024 (edited) I a bit ashamed to ask, but I have problems to install TB. I try it on a sub domain, with ssl. My hoster is Hetzner. I did this is the past dozen times but this time I do not know what I doing wrong. I create the subdir that is accessible via sub domain on the host. Then I extract the tb install .zip and start /install/index.php. Step 1 and 2 appear as usual but then I get the annoying error: Link to database cannot be established: SQLSTATE[HY000] [2002] php_network_getaddresses: getaddrinfo failed: Name or service not known I used thirtybees-v1.4.0-php7.4.zip and the host's server version of php matches 7.4. Edited October 11, 2024 by Pedalman
0 the.rampage.rado Posted October 11, 2024 Posted October 11, 2024 It sound like the installer is failing to connect you your db server. If Hetzner has Softaculous you can direclty install through it - select your subdomain (it has to be preconfigured), install the latest stable version, update to edge, voilà!
0 datakick Posted October 11, 2024 Posted October 11, 2024 I remember that some old version of thirty bees had issues when they encoutenr system compatibility problem during installation. Instead of displaying error message it displayed just blank error page. Try use 1.5.1 installation package instead.
0 datakick Posted October 11, 2024 Posted October 11, 2024 Also, before installation, ensure that your PHP has following extensions installed / enabled: Required: bcmath gd json mbstring openssl mysql (PDO only) xml (SimpleXML, DOMDocument) zip Recommended: imap (for allowing to use an IMAP server rather than PHP's built-in mail function) curl (for better handling of background HTTPS requests) opcache (not mandatory because some hosters turn this off in favor of other caching mechanisms) apcu/redis/memcache(d) 1
0 Pedalman Posted October 11, 2024 Author Posted October 11, 2024 (edited) 1.5.1 indeed displayed a compatibility hint. It was about allow_url_fopen . I then could install it as usual. This applies now to the older version thirtybees-v1.4.0-php7.4.zip, too. So, I had to activate allow_url_fopen on the server. Thank you for the tip! Edited October 11, 2024 by Pedalman
Pedalman
Edited by Pedalman4 answers to this question
