alwayspaws Posted October 12, 2017 Author Posted October 12, 2017 @daokakao said in How do I use a csv import for a large amount of colors & sizes for a single product?: @alwayspaws Why don't you make a sandbox environments for new features testing? It will ease your life. I can send my version of CSV for you. just try to import it? @daokakao said in How do I use a csv import for a large amount of colors & sizes for a single product?: @alwayspaws Why don't you make a sandbox environments for new features testing? It will ease your life. I can send my version of CSV for you. just try to import it? I tried to import it but didn't see these two when I went to open and save: Text values are in doublequotes: yes Save fields as on screen: yes
alwayspaws Posted October 12, 2017 Author Posted October 12, 2017 @jnsgioia said in How do I use a csv import for a large amount of colors & sizes for a single product?: @alwayspaws reverse them :) If you save the csv with a comma delimiter have the tb field separator comma, if you save it with a semi colon have the tb field delimiter semi colon @jnsgioia This is what I started out with and had no problems until I saw the combinations were put together.
DaoKakao Posted October 12, 2017 Posted October 12, 2017 @alwayspaws I've made a field separator as ^ sign, so at the import you should set this symbol as a field delimiter.
alwayspaws Posted October 12, 2017 Author Posted October 12, 2017 @DaoKakao Field delimiter is ^ (called caret) Should the Multiple value separator be semicolon if I use: size;color for combinations?
alwayspaws Posted October 12, 2017 Author Posted October 12, 2017 Great! It took a long time to import but now I can import the combinations. So let me see what happens.
alwayspaws Posted October 12, 2017 Author Posted October 12, 2017 @DaoKakao FIXED! Thank you so much for all the help. Will need to get this sorted out tomorrow, please. Have a great day / evening! :) I know it is updated because I edited the alt text for the image a little bit. :)
jnsgioia Posted October 12, 2017 Posted October 12, 2017 @alwayspaws they were put together because you had a comma between them and the program was expecting a semi colon.
alwayspaws Posted October 13, 2017 Author Posted October 13, 2017 @jnsgioia said in [Solved by DaoKaKao] How do I use a csv import for a large amount of colors & sizes for a single product?: @alwayspaws Yeah! :) @jnsgioia @DaoKakao Right on! @jnsgioia I propose that we clean up this post because we don't want anyone new coming along and trying all the wrong things from misconceptions. I'm going to delete what's unnecessary in my opinion. Please delete and update into one or two posts what is critical for potential users. You don't have to delete upvoted posts. Just combine them, if possible. Thanks!
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 Reopened due to questions about formatting sample combinations import csv. FYI: I switched to LibreOffice. I deleted all columns I never use. Are my combination attributes and values correctly formatted now?
jnsgioia Posted October 16, 2017 Posted October 16, 2017 @alwayspaws The Reference column is the sku for the combination. I use the product reference number-#. For instance, if my product sku (product reference number) is SG201 and I have 4 combinations for that product then the reference column would contain SG201-1 SG201-2 SG201-3 SG201-4. Looking at your spreadsheet it looks like you have that in the product id field. You should have your TB product ID (the number in the first column of your product list in the back office) in that column.
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 I went back to my old method just for the product combination ID's. Are my combination attributes and values correctly formatted now? 01508170264231combinations_import-template-worksheet.ods Do I use ALT text for the images on both the product and combinations .csv's? Do you use the image position column? If you do, do you add a specific url by color for each line? Update: the import did not work. It doesn't show my size selections:
jnsgioia Posted October 16, 2017 Posted October 16, 2017 @alwayspaws I don't know about the image questions. I upload the images with the product csv and then use @innercode's module to attach them to the combinations. Your spreadsheet looks ok to me. What did you use as your field delimiter?
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 Let's forget about the image alt text question. I wasn't talking about images. Did you update @innercode's module - nothing is working for me right now. I can't even get @innercode to be hotlinked. I'm done for a while. I have all the instructions for importing, etc. Thanks very much for the help.
DaoKakao Posted October 16, 2017 Posted October 16, 2017 Look: PRODUCTID is the 'artifical' index and primary key of 'products' table, it assigned automatically and should not be changed. The PRODUCTID field in the 'COMBINATIONS' table and in the combinations csv is binding with the 'products' table. So, when you have lets say 10 combinationsof one product, then you should have 10 lines in the combinations CSV, each of them starting with the same number. And this number MUST be equal with corresponding product_id in the 'products' table
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 @DaoKakao please see this, which is why I changed it: @jnsgioia said in <Reopened> How to use csv import for many colors & sizes for a single product?: @alwayspaws The Reference column is the sku for the combination. I use the product reference number-#. For instance, if my product sku (product reference number) is SG201 and I have 4 combinations for that product then the reference column would contain SG201-1 SG201-2 SG201-3 SG201-4. Looking at your spreadsheet it looks like you have that in the product id field. You should have your TB product ID (the number in the first column of your product list in the back office) in that column.
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 @daokakao said in <Reopened> How to use csv import for many colors & sizes for a single product?: Look: PRODUCTID is the 'artifical' index and primary key of 'products' table, it assigned automatically and should not be changed. The PRODUCTID field in the 'COMBINATIONS' table and in the combinations csv is binding with the 'products' table. So, when you have lets say 10 combinationsof one product, then you should have 10 lines in the combinations CSV, each of them starting with the same number. And this number MUST be equal with corresponding product_id in the 'products' table Here are my combination and then product .ods. I didn't add all the colors because I wanted to test them first: 01508174344041combinations_import-template-worksheet.ods 01508174418362products_import-worksheet.ods
DaoKakao Posted October 16, 2017 Posted October 16, 2017 @alwayspaws There's no contradiction with my explanations. When you use the 'Reference' field it is up to you with your own numbering scheme. But the IDs are assigned authomatically, if you change them manually, you will breal the links between products and their combinations, et c.
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 I'm very confused. The test product ID is 1000 and the test combination reference numbers are 1000-1 1000-2 1000-3 1000-4 1000-5 1000-6 1000-7 1000-8 I don't know what's wrong. I need a break. It took this long to test because my host had to reinstall my development site and then there was trouble and they had to do it manually. Sorry.
DaoKakao Posted October 16, 2017 Posted October 16, 2017 @alwayspaws There's a mistake: you've inserted the combinations ref numbers into the PRODUCT_ID field! And your last sample files seems to be ok
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 @daokakao said in <Reopened> How to use csv import for many colors & sizes for a single product?: @alwayspaws There's a mistake: you've inserted the combinations ref numbers into the PRODUCT_ID field! And your last sample files seems to be ok How can that be wrong?
alwayspaws Posted October 16, 2017 Author Posted October 16, 2017 Thank you to everyone for trying to help me. I will try again later.
DaoKakao Posted October 16, 2017 Posted October 16, 2017 Your screenshot Ok. But you have to match the fields "Reference #" and "Combination Reference" with corresponding fields at the import. I'd like to note, that in the TB's tables there's no "combination reference" field. There are "Reference" and the "Supplier reference" fields Also it could be another thing: at the importing page there's a switch 'Force all id numbers' - it also could affect data links between the tables, so you should try to turn it off
