Silver member
  1. Try this one: ``` .cart_navigation { float: left; } payWithAmazonMainDiv { float: right; } containerexpresscheckout { margin: 0 40px 0 0 !important; } ```
  2. This needs to be fixed in your tpl and css files.
  3. @Briljander said in How to make exact duplicate of site on same domain?: Just wondering. Is there any chance google will find the new site and index it and then get duplicate content? Is it possible to change robotfiles to in the cloned site to not make this happen? You should always use maintenance mode and add your IP. Google always found my testsites somehow.
  4. Thx! I confirm, that the problem is solved!
  5. Hehe thanks a lot! This was my first video ever :) Did it work for you?
  6. @alwayspaws said in How to make exact duplicate of site on same domain?: I don't want to install a new site. I want an exact duplicate of my current site. I have an older test site from before I upgraded my theme. Will it work if I just copy all the folders and files from live site to a subfolder for a test site? That sounds like the first step I do in my migration video... It works the same for tb as for ps.
  7. I just upgraded the module to 2.0 and wanted to configure it. But I always get this error: Cannot retrieve test results I believe, that my inputs are correct. Does this module work for you?
  8. It was one of the most asked feature back in ps times. We use a module for it. My opinion for such topics is always the same: Give the merchants the option to chose!
  9. I tested it on my server. I see now favicons in Firefox, which didn't show up before. But I think there is still a problem with multistore. It adds to every shop the same icon in Firefox (in Chrome & Edge it's correct).
  10. lol :D Is your question solved? If yes, feel free to mark the topic as solved.
  11. Which affialiate program?
  12. Have you reactivated the modules?
  13. Well why don't you combine these logo to one image file?
  14. @braffas from where comes the customer name? I guess a module hook!? You should make it dynamic. Just click on the hook on the settings and it gets green. Then maybe you have to delete the cache and afterward it should work.
  15. Oh then you probably need to work with the css files of your theme.
  16. You wanna change the look of Backoffice? Then you probably should checkout the setting for "employees". There you can chose different templates.
  17. How is this one called? I am now on plesk too and struggle a bit with the cron jobs...
  18. I think this is not possible with tb, since it's a fork of 1.6. What are you trying to achieve?
  19. Havouza did you find the solution?
  20. For such task you could either edit your theme or how moy2010 stated, use a html tool. You could try this one: http://contentbox.org/
  21. Good point. I didn't realize that. In my theme I use this: <a href="{$link->getPageLink('my-account', true)|escape:'html'}">{if $logged}{$customerName}{else}Mein Konto{/if}</a> It has similair problems... Is there a way to prevent some specific smarty variables from caching?
  22. @alwayspaws what you mean? Thirty bees doesn't offer any hosting. They just give you the software, which you can install on a server.
  23. I believe it's more like VPS. But you can test it two weeks for free. Pricing depends on how much RAM you choose and which hoster. Cloudways gives you the service of "managed". You get an easy interface and a live chat. For example redis can be installed by a kid. It's so easy there... The files are hosted on digital ocean or vultr (or some others).
  24. Yes TB is ready for live! We have three stores with thirty bees online (for example: www.spielezar.ch). They work great. But we aren't on shared hosting. We have a dedicated server. If your budget is small, but you wanna have a good solution, I recommend you cloudways: https://thirtybees.com/blog/thirty-bees-on-cloudways/ You can create a free trial there. You don't even have to give them payment details. So really no risks at all :)
  25. Oh ok :) I just tested cloudways two weeks ago. I really liked the performance, especially when you think, what you pay for.
