Everything posted by zen
Product list blank in backoffice of Thirty Bees
zen replied to Kenneth Nielsen's question in Technical help
but without any DB configured you won't be able to start TB in front or back office, no user login, nothing can work ! so it's strange, very unusal. -
you can edit this file : config/settings.inc.php And modifiy theses lines for DB access: -
What is your hosting provider ? also, I can have a look if you send me access in private. Best regards. -
I activated smarty cache on Performance setup page and all the options for CCC (Combine, Compress and Cache) are turned ON, I had small problems with minified css and js, that now is fixed 🙂
That means you want to get rid of Social Titles and Birthday on the user infos.. => Mission Done, you can select to ask gender title and birthday or not in the theme master Module.
Wat do you want as a default field : "Disconnection" instead ?
You now, have a new custom variable added to the module thememaster that "Hide step titles on order for mobile " tell me if it fits your needs 🙂
An installation theme error on a new fresh TB 1.3.0 installation
zen replied to pessoal2004's question in Technical help
it says that the theme is already installed.. so is it working already or what is blocking you now to use TB on this install ? -
This is fixed, as I put back the popup overlay message when adding a product in the cart, please confirm that it's working as well for you.
this is fixed and the listing grid will be something that I want to make it customisable from backoffice from dynamic to fixed numbers, for now it is dynamic with flexbox system and justify alignment Which text would you like to see decreasing in size for mobile ?
The the purpose of this thread is to complete the theme for the basic needs, adding more function is for the next step but if it's easy why not doing it on the way. Waiting for your bug report in order to fix them. 🙂
"the button could disappear in order to not have the same button again." => yes.. but it will make some moving effect into the page that i don't really want to happen. "It's a little detail, but maybe you can make that modal bigger without horizontal scroll."=>That is fixed 🙂
Thank you for this report, I gonna fix it soon. For now I still don't know If there will be a paid version one day, I have to finish this one first. I might also provide later some services to integrate custom theme design/mockup for merchants.
Job done, I added the quantity on the shopping cart prod line with and the option to show it or not on the theme Master module.
OK, I did changed the colors.. the active step is dark now and to complete is light grey and completed is dark grey
OK, I might add this as well and connect it to the module so user can decide to show it or not on the shopping cart summary, please wait before I can add this feature 🙂
OK, the step you are in is grey, the step done are black, the step to be done are light grey.. isn't that logic then ?
Yes, I just finished it, please try it and tell me if it suits your needs ! 🙂
=> Yes, I took it out, as it's on step 2 as well. What colors scheme would you think work best ?
go with PHP 7.4 then 🙂
OK, I think that showing addresses is needed, I don't really want to hide them, but then I find out that on the STEP 1, it's not necessary to show addresses there.. what do you think about it ?
Here is a screenshot of the Order Step 1 Cart summary for a Mobile(iphone 12/13) with 390px of width. And the Order Step 2 Addresses and Shipping selection enjoy 🙂
You are right, that is why i added the mod into the theme this morning, and I also modify few things in order to make it works better, also the carrier page has been made more mobile friendly. Hope you like it 🙂
