elund Posted July 8, 2018 Posted July 8, 2018 After upgrading to version 1.0.4 I have problems with the price shown on the product page when using quantity discount as shown below. Is this a bug in vesrion 1.0.4 or a compatibilty problem with my theme and version 1.0.4? It worked fine with version 1.0.3.
0 the.rampage.rado Posted July 8, 2018 Posted July 8, 2018 Are you sure your config is correct - special price? Such bug was present on PS where the 'you save' amount was changed with the savings amount.
0 Traumflug Posted July 9, 2018 Posted July 9, 2018 Certainly a thing to test. Perhaps the bug is still present.
0 elund Posted July 10, 2018 Author Posted July 10, 2018 @the-rampage-rado said in Problem with price on product page after upgrade to 1.0,4: Are you sure your config is correct - special price? Such bug was present on PS where the 'you save' amount was changed with the savings amount. Yes, I am pretty sure - or at least - it worked fine before the upgrade ;-)
0 elund Posted August 17, 2018 Author Posted August 17, 2018 This is still a problem in version 1.0.6
0 Traumflug Posted August 17, 2018 Posted August 17, 2018 https://github.com/thirtybees/thirtybees/issues/574
0 Traumflug Posted August 18, 2018 Posted August 18, 2018 Hmm. @yaniv14 can't reproduce this on 1.0.6, see comment on the Github issue. Which leads to the question: what is different between your installation and Yanivs? Any additional modules? A custom theme? Does it happen with new products as well (it might be result of something stored in the wrong place in the database)?
0 yaniv14 Posted August 18, 2018 Posted August 18, 2018 What I did is to install a fresh new 1.0.6 with Hebrew language and all demo products. After that I've edited one of the products and added 2 different quantity discounts. Both shows fine in the quantity discount table and both changed the product price once reached the desire amount.
0 Traumflug Posted August 19, 2018 Posted August 19, 2018 community-theme-default just received the fix provided by @yaniv14, so it'll go into the next release. Thank you very much! P.S.: or was the fix provided by @datakick ? The commit message reads Petr Hučík, thanks go to this person :-)
0 elund Posted August 20, 2018 Author Posted August 20, 2018 @traumflug said in Problem with price on product page after upgrade to 1.0,4: Hmm. @yaniv14 can't reproduce this on 1.0.6, see comment on the Github issue. Which leads to the question: what is different between your installation and Yanivs? Any additional modules? A custom theme? Does it happen with new products as well (it might be result of something stored in the wrong place in the database)? I use the TB compatible Panda theme from https://www.sunnytoo.com/product/panda-creative-responsive-prestashop-theme. If the line below is the only change to the community theme, then it unfortunately doesn't help me, so I have to investigate further. ~~if (discountedPrice != 0) {~~ if (displayDiscountPrice != 0 && discountedPrice != 0) { SInce it worked before I would assume there must have been a correction to the core code causing this issue. The correction to the core can of course be the right thing to do.
0 elund Posted August 28, 2018 Author Posted August 28, 2018 Where is "displayDiscountPrice" defined and set?
0 doclucas Posted August 29, 2018 Posted August 29, 2018 @elund said in Problem with price on product page after upgrade to 1.0,4: Where is "displayDiscountPrice" defined and set?
0 elund Posted August 29, 2018 Author Posted August 29, 2018 Wauw, that fix my issue after the upgrade to 1.0.4. Thanks a lot :-)
elund
12 answers to this question
