AndyC Posted February 23, 2020 Share Posted February 23, 2020 (edited) Have just come across a new error while trying to add images to a new product Anyone have any idea " If I turn on Debug I get I disabled the JSON module but that didn't help Just tried a refresh with debug on and this came up as well Edited February 23, 2020 by AndyC Link to comment Share on other sites More sharing options...
wakabayashi Posted February 23, 2020 Share Posted February 23, 2020 Well It clearly says, that you use an override. So the error will come from there... Either you have added an override or (more likely) an external module. Link to comment Share on other sites More sharing options...
AndyC Posted February 23, 2020 Author Share Posted February 23, 2020 (edited) mmmm I just renamed the first file images under overrides / classes and it's working now . Seems to be coming from a module called imagehover which hasn't been installed before now ....Why would there be a file belonging to this in overrides Edited February 23, 2020 by AndyC Link to comment Share on other sites More sharing options...
Traumflug Posted February 24, 2020 Share Posted February 24, 2020 Perhaps because the module was installed at some time, then removed again. Many modules don't clean up properly on uninstallation. Link to comment Share on other sites More sharing options...
AndyC Posted February 24, 2020 Author Share Posted February 24, 2020 1 hour ago, Traumflug said: Perhaps because the module was installed at some time, then removed again. Many modules don't clean up properly on uninstallation. Thanks did not know that ... I'll rename file for a while in case it is still needed sometime Link to comment Share on other sites More sharing options...
