Alex Hansen Posted May 6, 2021 Posted May 6, 2021 (edited) Hi For advertising we been asking of an live XML product feed - What does others use (and recomend) here? Edited May 6, 2021 by Alex Hansen
haylau Posted May 6, 2021 Posted May 6, 2021 Check out @datakick’s module : https://www.getdatakick.com 1 1
veganline Posted May 6, 2021 Posted May 6, 2021 (edited) I don't know. I was about to reply that I used https://github.com/dim00z/gshoppingflux but, on checking, I don't and cannot install. Maybe someone else can install a free xml feed somehow? -------------first posted May 6th ; update June 5thI have bought the Datakick module. It's twice the price of the cheapest Prestashop one, but it looks like something that will teach me what data I have and how I can put it into an xml feed in a foolproof and pretty way for any purpose and any way I like, so worth the extra. Otherwise I would have to pay for a module for every single platform. There's a half price version that lasts a year, and a free fortnight to get set-up if you are quick at setting-up. Once done, the module makes an "end point" such as "example.com/endpoints/google.xml", and creates a fresh up-to-date file from the database whenever anyone such as a google bot asks for it. I can't give more of a review because I'm working on adding schema.org tags to products first, just to see how far I can get before learning how to make xml feeds work. Edited July 8, 2021 by veganline link to developer site
veganline Posted July 8, 2021 Posted July 8, 2021 (edited) Google Shopping Flux free module https://github.com/dim00z/gshoppingflux Also listed as a free PS module on https://www.megventure.com/ https://ko-fi.com/casper_o can take money for work on it, and there is a link to a thread on a similar shopping cart's forum pages where he has answered questions over the years. Once installed, the free module has neat options for set-up although shipping options are "experimental". I haven't made them work yet. It might work on Pricerunner and Shopalike apparently, and works on Facebook, but it isn't flexible like https://www.getdatakick.com so I am learning on both. Edited July 25, 2021 by veganline
x97wehner Posted July 8, 2021 Posted July 8, 2021 On 5/6/2021 at 12:20 PM, haylau said: Check out @datakick’s module : https://www.getdatakick.com second this one
x97wehner Posted February 29, 2024 Posted February 29, 2024 On 5/6/2021 at 12:20 PM, haylau said: Check out @datakick’s module : https://www.getdatakick.com Also recommend this
