musicmaster Posted November 13, 2022 Posted November 13, 2022 (edited) The Panda theme produces quite a lot of warnings for the error log. Usually they are harmless. In this post I will list the warnings and the fixes. As the Panda theme hasn't been upgraded for some time this will enable you to do it yourself. Make sure to update your modules and Thirty Bees to the last version. Make also sure that you have the latest version of Panda: older versions are quite different and with them the line numbers won't match. I haven't enabled all modules and tested them in all corners. So there may still be hidden problems. If you encounter a problem and find a solution, please report it here so that I can add it to the list. If you aren't able to solve it I will be happy to help you. SunnyToo has promised that they will release a new version. blockcart-json.tpl Warning: Creating default object from empty value in /home/public/sites/www.shop.com/cache/smarty/compile/11/2b/10.file.blockcart-json.tpl.php on line 218 /themes/panda/modules/blockcart-json.tpl The offending line is line 81. It looks so: "free_ship": {(!$shipping_cost_float && !count($cart->getDeliveryAddressesWithoutCarriers(true, $errors_back)))|json_encode}, To fix it it should be changed to by deleting the $errors_back argument "free_ship": {(!$shipping_cost_float && !count($cart->getDeliveryAddressesWithoutCarriers(true)))|json_encode}, If you have another template that overrides the blockcart template you are likely to encounter the same issue. A very similar fix was made to the blockcart module. That fix provides also three other fixes that should be implemented. These are in the more remote parts of the code so you won't see the errors often: /themes/panda/modules/blockcart/includes/dropdown.tpl line 113 change: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true, $errors))} to: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true))} /themes/panda/order-carrier-advanced.tpl line 264 and /themes/panda/order-carrier-opc-advanced.tpl line 250 change: {assign var='errors' value=' '|explode:''} to: {assign var='errors' value=[]} blockviewed There is a fix for the TB version of this module that you can also apply to your blockviewed_mod. It is discussed here and you can find the code here. As it concerns quite a lot of code I haven't copied it here. Note that this concerns a possible problem and it doesn't produce error messages - except for the browser console when the rare problem really happens. blockwishlist [] PHP Warning: count(): Parameter must be an array or an object that implements Countable in /home/public/sites/www.webshop.com/cache/smarty/compile/ba/cb/c4/bacbc7.file.blockwishlist-extra.tpl.php on line 25 /themes/panda/modules/blockwishlist/blockwishlist-extra.tpl Line 28 looks like this: {if isset($wishlists) && count($wishlists) > 1} This should be changed to {if isset($wishlists) && is_array($wishlists) && count($wishlists) > 1} breadcrumb.tpl [] PHP Warning: Creating default object from empty value in /home/public/sites/www.webshop.com/cache/smarty/compile/fe/8c/6b/fe1_0.file.breadcrumb.tpl.php on line 32 The offending line is: {$matchCount = preg_match_all('/<a.+?href="(.+?)"[^>]*>([^<]*)<\/a>/', $path, $matches)} The problem is that $matches is not defined. So you need to add a line before this line: {$matches = []} guest.php [] PHP Notice: Trying to access array offset on value of type bool in /home/public/sites/www.webshop.com/classes/Guest.php on line 207 This error can happen in older shops. It happens because some entries are lacking in the ps_operating_systems entries for more recent OS's are missing. If you scroll a bit up from line 207 you will see which OS's are defined in the software. paypal.php and stnewsletter Array and string offset access syntax with curly braces is no longer supported in file /home/public/www.website.com/modules/paypal/paypal.php at line 2729 This type of error is quite common and happens also with other modules. It has to with the syntax for arrays. Normally you write something like "$myarray[8]". However, there is an old type of syntax that uses curly brackets instead of the square brackets. In that case the same declaration looks like "$myarray{8}". In PHP 8 the latter syntax is no longer allowed. So you need to replace the curly brackets with square brackets. So if ((int) $num1{$i} > (int) $num2{$i}) will be replaced by if ((int) $num1[$i] > (int) $num2[$i]) stnewsletter has a similar problem on line 122. stgadwordsconversion.php [] PHP Warning: Undefined array key "total" in /home/public/sites/www.webshop.com/cache/smarty/compile/53/63/eb/5363eb.file.front.tpl.php on line 32 [] PHP Warning: Undefined array key "iso_code" in /home/public/sites/www.webshop.com/cache/smarty/compile/53/63/eb/5363e.file.front.tpl.php on line 34 [] PHP Warning: Undefined array key "total" in /home/public/sites/www.webshop.com/cache/smarty/compile/53/63/eb/5363.file.front.tpl.php on line 32 [] PHP Warning: Undefined array key "iso_code" in /home/public/sites/www..webshop.com/cache/smarty/compile/53/63/eb/5363.file.front.tpl.php on line 34 /modules/stgadwordsconversion/stgadwordsconversion.php This error always comes in fourfold when an order is made. Two times before the payment is made and two times in the callback from the payment provider. This is a module that used to be provided by SunnyToo. However, it is no longer supported and for me that was a reason to stop using it. stmegamenu.php [] PHP Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home/public/sites/www.webshop.com/modules/stmegamenu/stmegamenu.php on line 3724 [] PHP Warning: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? in /home/public/sites/www.webshop.com/modules/stmegamenu/stmegamenu.php on line 3739 /modules/stmegamenu/stmegamenu.php As "continue" is the old version and it works so I have replaced "continue" here with "break". stnewsletter Error message in the browser console from php-debug.js Deprecation: Array and string offset access syntax with curly braces is deprecated in modules/stnewsletter/stnewsletter.php at line 123 php-debug.js:53:39 Change in /modules/stnewsletter/stnewsletter.php on line 123 if ($this->_cookie_path{0} != '/') into if ($this->_cookie_path[0] != '/') stthemeeditor Symptom: when in the backoffice you want to configure this module it your modules page the call keeps hanging until you get some kind of timeout (for example a 504 error). When you look in the browser console under Network you see that the status of the call is "pending". When you look under Timing you see "call is not finished yet". This happens when some SunnyToo webpage is down. Just waiting will solve the problem. But if you want to access your theme-editor immediately here is a fix. The problem is in the function getVerInfo in the file /modules/stthemeeditor/ThemeLicense.php public function getVerInfo() { if (!isset($_SESSION['st_version_info']) || !$_SESSION['st_version_info']) { $api_url = 'http://biz236.inmotionhosting.com/~sunnyt7/version.php'; $theme = $this->getTheme(); $param = array( 'theme' => $theme, 'ver_only' => false, ); if ($data = $this->makeCall($param, $api_url)) { $_SESSION['st_version_info'] = $data; } else { $_SESSION['st_version_info'] = ''; } } return $_SESSION['st_version_info']; } The link to inmotionhosting no longer works. Unfortunately that makes the function makeCall hang rather than return false. So a solution is to replace if ($data = $this->makeCall($param, $api_url)) { $_SESSION['st_version_info'] = $data; } else { $_SESSION['st_version_info'] = ''; } with just the line $_SESSION['st_version_info'] = ''; Possibly this is a temporary problem and SunnyToo will fix it. The themeconfigurator module After I had upgraded PHP to version 8.1 I found that I couldn't access my backoffice. It had an error in the themeconfigurator module. This module was not active. Yet it was somewhere accessed by the theme. The problem here is that Thirty Bees doesn't upgrade modules that are not active. So in this shop - a migrated Prestashop - I still had the old Prestashop version. The solution was to delete this old version and copy a new version of this module from a recent Thirty Bees installation. Here an update file that fixes some of the issues. yotpo.php The Yotpo module produced the following warning: Warning: count(): Parameter must be an array or an object that implements Countable in /home/public/sites/www.webshop.com/modules/yotpo/yotpo.php on line 268 The relevant code was: $id_image = Product::getCover($id_product); if (count($id_image) > 0) Obviously this was a programming error on the side of Yotpo. $id_image is just a variable, not an array. So the corrected code became: $id_image = Product::getCover($id_product); if ($id_image > 0) The backoffice Modules page Under PHP 8.1 you will see in the backoffice Modules page warnings like the following: Deprecated: Optional parameter $type declared before required parameter $id_lang is implicitly treated as a required parameter in StMultiLinkGroup.php on line 127 The offending code in this case is: public static function getLinkGroup($identify,$type=1,$id_lang) You can solve this by stripping "=1" from the "$type=1" part. The same applies to other function declarations with the same problem. Optional parameter $nbr declared before required parameter You will see a lot of these warnings when you open the Modules page in the backoffice. Guilty are function declarations like this public static function getByCustomer($id_customer, $p = 1, $n = 0, $id_lang, $id_shop, $get_total = false) The problem are those definitions like "$p = 1". You can leave the values out. So the above function would become: public static function getByCustomer($id_customer, $p, $n, $id_lang, $id_shop, $get_total = false) As these are harmless I haven't changed them myself. Edited March 18, 2023 by musicmaster 5
AndyC Posted November 24, 2022 Posted November 24, 2022 Thanks for this ,, I see the breadcrumb issue is listed... I'm giving it another go this weekend
AndyC Posted November 25, 2022 Posted November 25, 2022 Just been though editing all the files to be ready, then I saw you had taken the time to upload them, so thank you for doing that I'll see how I get on tomorrow or Sunday
DRMasterChief Posted November 3, 2024 Posted November 3, 2024 Hello @musicmaster unfortunately, I get a similar warning 1-2 times per minute, and the error log file becomes very large as a result. I'm not sure if this could cause another problem. I don't use Panda theme but maybe someone can give me a hint? The error is: PHP Warning: Creating default object from empty value in /home/mysite/public_html/cache/smarty/compile/c2/57/b6/c257b667changed77a0888some39bf5thing5b736_0.file.blockcart.tpl.php on line 257 and the line 257 in this file is: <?php $_smarty_tpl->_assignInScope('free_ship', count($_smarty_tpl->tpl_vars['cart']->value->getDeliveryAddressesWithoutCarriers(true,$_smarty_tpl->tpl_vars['errors']->value)));?> Thank you very much
Yabber Posted November 3, 2024 Posted November 3, 2024 @DRMasterChief In blockcart.tpl template, change: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true, $errors))} to: {assign var='free_ship' value=count($cart->getDeliveryAddressesWithoutCarriers(true))}
DRMasterChief Posted November 3, 2024 Posted November 3, 2024 Hi @Yabber thank you! I already have this since months.... today i see that error_log is 60MB... then i checked it. I now have changed the blockcart.tpl also in Community Default Theme (i dont use this, i have an other template since 1st day), and now it works. No error warnings anymore. Strange behaviour.... ?!
