Thirtybees and Stripe
I've just installed the Stripe Module
It's currently in test mode using test keys.
The payment appears to process in Stripe, but on return to the validation page I get this error
  • An error occurred:
  • No charges associated with payment
Payment is taken, but my TB doesn't process the order.
There's nothing in Java Console.
Any ideas?
Cheers ... Fizz
11 answers to this question
What methode did you use ?
We are seeing issues with Sofort not creating orders.
Other then that we see all orders going in.
I'm wondering if there is a configuration error on the site.
I also get the same problem using MyPOS.
Slightly different - the website forwards to MyPOS gateway, the card is authenticated properly, but then the transaction fails on handover back to the site.
Any ideas how to bug track this?
18 minutes ago, nickz said:
error logs in your server should have that data.
Hi Nickz - there are no server side errors logged. The error message is generated by TB and not the server.
The issue doesn't appear to be from Stripe.
If I select the 'Enable Stripe Checkout' option in settings, I get an error 404 page error when trying to check out.
I've tried re-installing the stripe module - but still no go
Edited by Fizzwizz
I seem to be experiencing errors in 2 places
I have Thirty Bees 1.4.0
My Stripe API is 2022-11-15, though I've been having this issue with API 2022-08-01
I also have the Panda theme installed.
I have 2 issues that I can see. I'm in test mode and on test transaction stripe processes the transaction, however on return to the stripe validation module at mysite.com/module/stripe/validation?type=cc returns the error:
An error occurred:
The second error is if I select 'Enable Stripe Checkout' in Stripe Checkout options. When I go to checkout, I get a server error 500 at page mysite.com/orders after ticking the terms and conditions box then clicking 'proceed to checkout'
Edited by Fizzwizz
Looks like the latest Stripe API has broken the module again.
It also seems I cannot rollback the Stripe API (please correct me if I'm wrong)
ThirtyBeesStripe\Stripe\Error\ApiConnection
You cannot use `line_items.amount`, `line_items.currency`, `line_items.name`, `line_items.description`, or `line_items.images` in this API version. Please use `line_items.price` or `line_items.price_data`. Please see https://stripe.com/docs/payments/checkout/migrating-prices for more information.
in file /home/customer/www/mysite.co.uk/public_html/modules/stripe/classes/GuzzleClient.php at line 237
what does stripe say?
I think there is also a stripe redirect page available.
The module is not compatible with stripe api version 2022-08-01 or newer.
I had this problem aswell.
The fix
There is a way to fix this, don't panic. Uninstall the current Stripe module on your thirty bees installation completely. Then, head over to Stripe official (SCA-ready) Module - PrestaShop Addons and what you need to do is click "Download", make an account with PrestaShop or login to one, then download again and click "PRESTASHOP 1.6." and then just install the module in the back office of your thirty bees as you would with any other .zip module.
Then, simply configure the module as desired. It will work 100% I can guarantee as  this is what I am using currently with thirty bees and it is processing payments perfectly.
When you configure the module, enter your pbulic and secret keys and also click on the blue "Connect to stripe" button, let it connect correctly as usual. If the button doesn't update after clicking connect to stripe and connecting, dont panic. It is like that with me too. That is the only compatibility issue but its VERY minor. once it is connected and the keys are entered it does work properly.
I hope this helps 🙂 If it doesn't, let me know, I can help if needed
