the.rampage.rado Posted March 1, 2023 Posted March 1, 2023 Hello, Many times when I search for sports goods from previous years I open up sites that list those as out of stock and they are hidden in the normal product listings. But google sees this "half-inactive" product and shows a result. I click and open this site, otherwise I would not click this result. Currently I set all old collection items to available - NO and I make 301 reddirect to analog product. So after some time I lose all those results in google. In your opinion what is the best config for such products? Availability - Yes Visibility - Search only or should I continue to 301 to new products? I'm even not sure that the first scenario will result to the same behaviour I described in the start. If I enable search indexation will google 'search' for some products in order to get to those hiden products that are only search-visible?
30knees Posted March 1, 2023 Posted March 1, 2023 (edited) We do: Enabled: Yes Visibility: Nowhere Availabel for order: No Like this they still show up in search engines but not in the store. For some products I'll add a text saying this one is discontinued but check out this new one and link to the new one. Edited March 1, 2023 by 30knees 2
the.rampage.rado Posted March 3, 2023 Author Posted March 3, 2023 On 3/2/2023 at 12:12 AM, 30knees said: We do: Enabled: Yes Visibility: Nowhere Availabel for order: No Like this they still show up in search engines but not in the store. For some products I'll add a text saying this one is discontinued but check out this new one and link to the new one. I'll try your setup for few products. What if I have 'available for order' set to Yes and I have no stock? I believe nothing changes in FO?
the.rampage.rado Posted March 3, 2023 Author Posted March 3, 2023 Just tried your settings - those products are not visible in the sitemap. Why and how will then Google bot reach them?
30knees Posted March 3, 2023 Posted March 3, 2023 That's strange. They're in my sitemap. But if they've already been indexed, does it not matter whether they're in the sitemap? Here the settings:
datakick Posted March 3, 2023 Posted March 3, 2023 They should not be in sitemap: https://github.com/thirtybees/sitemap/blob/c1ade8ced29c953c5dd2e19d992cbcf437628066/sitemap.php#L697 Sitemap shows only products that match both these criteria: active = 1 AND visibility != 'none'
the.rampage.rado Posted March 3, 2023 Author Posted March 3, 2023 (edited) @datakick - how can I achieve the same behaviour? Is it possible at all at the moment? Edited March 3, 2023 by the.rampage.rado
30knees Posted March 4, 2023 Posted March 4, 2023 @the.rampage.radoCouldn't you modify the file like this so it shows? active = 1 AND visibility = 'none'
the.rampage.rado Posted April 10, 2023 Author Posted April 10, 2023 Search only means "search in the shop". It does not mean Google search. Tried and tested this - they don't get indexed by Google.
