Hi. I currently use SendInBlue for our digital marketing efforts. But they've now discontinued support for PS 1.6, removed the module from their site, and only support PS 1.7. Their current module that I already have, doesn't fully work anymore because of this.
I'm curious what other comparable tools others may be using that natively integrate with TB?
We use the newsletter module Newsletter Pro v5.0.3 - by ProQuality and SMTP to our transactional email service. The module is not super but it works for newsletters.
Maybe you can have it updated by datakick?
  • 2 weeks later...
@30knees I like very much the option to fill the newsletter with products from the db. I am with Cleverreach and it is too much hassle to copy and paste all product links and image links manually since it has no access to my 'db'. If I got it right, this email module runs on your host, right?
If it runs on your host where your shop runs, you do not fear that it might be 'blocked' in anyway? I heard that it could happen and that it would be best therefore to send email newsletter via a service with its own domain.
Yes. The module is installed in thirtybees and runs there. I use https://elasticemail.com/ as the email provider. I can set this in the module.
  • 3 months later...
  • 2 years later...
On 12/18/2025 at 1:02 AM, mamta25 said:
Hey,
Since SendInBlue no longer supports PrestaShop 1.6, you could consider using GetResponse, MailerLite or Klaviyo, which have PrestaShop modules for newsletters and automation. Other platforms like Mailchimp, Omnisend and ActiveCampaign can also work if connected through integration tool such as Make or Pabbly.
Please check the forum before posting. I modified the Brevo (Formerly SendInBlue) latest module to work on thirty bees. You can download it here https://forum.thirtybees.com/topic/6963-brevo-marketing-module/
