netamismb Posted July 8 Share Posted July 8 I wonder if is fine to remove the it scripts below. It looks like remove it I can improve the performance, but I have no idea if the above scripts is needed. <link rel="stylesheet" type="text/css" href="//cdnjs.cloudflare.com/ajax/libs/cookieconsent2/3.0.3/cookieconsent.min.css" /> <script src="https://cdnjs.cloudflare.com/ajax/libs/cookieconsent2/3.0.3/cookieconsent.min.js"></script> from eucookieconsent/views/templates/hooks/cookieconsent.tpl at master · thirtybees/eucookieconsent (github.com) Page speed screenshot Link to comment Share on other sites More sharing options...
Yabber Posted July 9 Share Posted July 9 This module does not comply with current EU law, which requires a cookie manager installed, where the customer chooses which cookies to allow and which not to allow. So something like this: https://optlasers.com/ Link to comment Share on other sites More sharing options...
netamismb Posted July 9 Author Share Posted July 9 5 hours ago, Yabber said: This module does not comply with current EU law, which requires a cookie manager installed, where the customer chooses which cookies to allow and which not to allow. So something like this: https://optlasers.com/ May I ask what module do you use? Link to comment Share on other sites More sharing options...
Yabber Posted July 9 Share Posted July 9 1 hour ago, netamismb said: May I ask what module do you use? This is the module: https://www.lineagrafica.es/en/modulos-prestashop/eu-cookie-law-banner-blocker-prestashop-module/ 1 Link to comment Share on other sites More sharing options...
the.rampage.rado Posted July 9 Share Posted July 9 You can try https://github.com/tagconcierge/tc-prestashop-gtm-consent-mode-banner-free I'm using it. The only drawback is that is not multilingual but if you have a 2+ lang site you can use their paid module. I downloaded the js files and modified the code to work locally and everything in Google is OK so far. 1 Link to comment Share on other sites More sharing options...
