netamismb Posted July 17 Share Posted July 17 (edited) Hello, I have update TB from 1.3 to 1.5.1 and currently we face two issues: 1. When duplicate the product, the tags, combination, features are not duplicated. Is this an expected behaviour? 2. When save a product, get the error : Duplicate entry '2243-0-0-0-2014-08-01 00:13:44-2014-08-31 23:59:00-1-0-0-0-0-1-1' for key 'id_product_2'. Also, in module PHP logs i get some exception, not sure they are related with above. Search Reset Exception UnexpectedValueException: RecursiveDirectoryIterator::__construct(/home/rockgdzb/rock4u.ro/cache/smarty/cache/socialsharing_header/992/1/36/e9): failed to open dir: No such file or directory vendor/smarty/smarty/libs/sysplugins/smarty_internal_runtime_cacheresourcefile.php:67 1 5 days ago 07/12/2024 14:13:29 View Exception UnexpectedValueException: RecursiveDirectoryIterator::__construct(/home/rockgdzb/rock4u.ro/cache/smarty/cache/productscategory/2737/6/1/36/04/cf/36): failed to open dir: No such file or directory vendor/smarty/smarty/libs/sysplugins/smarty_internal_runtime_cacheresourcefile.php:67 1 5 days ago 07/12/2024 14:13:24 View Exception UnexpectedValueException: RecursiveDirectoryIterator::__construct(/home/rockgdzb/rock4u.ro/cache/smarty/cache/socialsharing_header/111/1/36/e9/47): failed to open dir: No such file or directory vendor/smarty/smarty/libs/sysplugins/smarty_internal_runtime_cacheresourcefile.php:67 1 6 days ago 07/11/2024 11:08:53 View Exception ThirtyBeesDatabaseException: Duplicate key value classes/ObjectModel.php:608 22 Today 07/11/2024 11:06:30 View Exception UnexpectedValueException: RecursiveDirectoryIterator::__construct(/home/rockgdzb/rock4u.ro/cache/smarty/cache/productscategory/468/4/1/36/04): failed to open dir: No such file or directory vendor/smarty/smarty/libs/sysplugins/smarty_internal_runtime_cacheresourcefile.php:67 1 7 days ag Can you please advice? Edited July 17 by netamismb Link to comment Share on other sites More sharing options...
the.rampage.rado Posted July 17 Share Posted July 17 1. It's a known bug, some other parts are not duplicated also. 2. Are you copying products that have Specific price rules attached to them? Link to comment Share on other sites More sharing options...
datakick Posted July 18 Share Posted July 18 Please try to reproduce on bleeding edge - there were few bugs related to product duplication fixed already. If you problem is still reproducible on bleeding edge, file a new github issue. 1 Link to comment Share on other sites More sharing options...
theMerchantDev Posted July 18 Share Posted July 18 Can someone please paste here the Bleeding Edge link? I have heard from but I didn't know it. Thanks. Link to comment Share on other sites More sharing options...
Yabber Posted July 19 Share Posted July 19 10 hours ago, theMerchantDev said: Can someone please paste here the Bleeding Edge link? I have heard from but I didn't know it. Thanks. Bleeding edge is a development version available as a repository on github: https://github.com/thirtybees/thirtybees And you could say that every day is different. You can perform an upgrade of your thirtybees to Bleeding edge by changing the Core Updater configuration: 1 Link to comment Share on other sites More sharing options...
netamismb Posted August 16 Author Share Posted August 16 I have downgrade to ThirtyBees 1.4 but I still have issues with product duplicates. While I can duplicate a product, the combination and features are not duplicate. Furthermore, if I edit combination or feature I can't save it. I get the following error: Can be something related to database? I have another shop running on ThirtyBees 1.4 and there the product duplicates are working fine. Any idea what is going wrong? Maybe can point me to any commit or PR to solve the issue. Link to comment Share on other sites More sharing options...
netamismb Posted August 18 Author Share Posted August 18 I found in error_logs. I don't understand where is the issue, is trying to insert two times in table ps_specific_price?: Exception Message: ThirtyBeesDatabaseException: Duplicate key value ThirtyBeesDatabaseException: Duplicate entry '1547-0-0-0-2014-08-01 00:13:44-2014-08-31 23:59:00-1-0-0-0-0-1-1' for key 'id_product_2' Location: classes/ObjectModel.php line 640 SQL INSERT INTO `ps_specific_price` (`id_specific_price_rule`, `id_cart`, `id_product`, `id_shop`, `id_shop_group`, `id_currency`, `id_country`, `id_group`, `id_customer`, `id_product_attribute`, `price`, `from_quantity`, `reduction`, `reduction_tax`, `reduction_type`, `from`, `to`) VALUES ('1', '0', '1547', '1', '0', '0', '0', '0', '0', '0', '-1', '1', '0.08', '1', 'percentage', '2014-08-01 00:13:44', '2014-08-31 23:59:00') Link to comment Share on other sites More sharing options...
netamismb Posted August 18 Author Share Posted August 18 On 7/18/2024 at 9:01 AM, datakick said: Please try to reproduce on bleeding edge - there were few bugs related to product duplication fixed already. If you problem is still reproducible on bleeding edge, file a new github issue. I can't really use bleeding edge, I need to fix this is production. Link to comment Share on other sites More sharing options...
the.rampage.rado Posted August 18 Share Posted August 18 52 minutes ago, netamismb said: I can't really use bleeding edge, I need to fix this is production. bleeding edge channel is 99.9% production ready as datakick makes the commits there and everything is tested before. So if it is the only issue you have with it you can backup your store and try. I only roll my shops on bleeding. Link to comment Share on other sites More sharing options...
netamismb Posted August 18 Author Share Posted August 18 (edited) 3 hours ago, netamismb said: I can't really use bleeding edge, I need to fix this is production. I upgrade to bleeding edge and it looks like the issue with issues with product duplicates is fixed, but now I have another huge issue, all the images disappears and the Regenerate thumbnails doesn't work. I mean, in admin Preferences / Images/ Regenerate thumbnails nothing happens when press Regenerate. In the meantime I restore the backup. Edited August 18 by netamismb Link to comment Share on other sites More sharing options...
theMerchantDev Posted August 18 Share Posted August 18 I remember to read both issues here at Forum last weeks, duplicate and thumbs, and they were answered with solution if I remember correctly. Please check. Link to comment Share on other sites More sharing options...
the.rampage.rado Posted August 18 Share Posted August 18 3 hours ago, netamismb said: I upgrade to bleeding edge and it looks like the issue with issues with product duplicates is fixed, but now I have another huge issue, all the images disappears and the Regenerate thumbnails doesn't work. I mean, in admin Preferences / Images/ Regenerate thumbnails nothing happens when press Regenerate. In the meantime I restore the backup. Since 1.5.1 there is a huge image section rewrite, nearly everything regarding to images is redone so you will have to give little bit more details - where they disappeared, what theme are you using, little something to work with... Regarding the duplication issues - you can go to github and search for commits that mention product duplication issues and apply the fixes manually to your install if you're not planning to rolling back to edge soon. Link to comment Share on other sites More sharing options...
netamismb Posted August 18 Author Share Posted August 18 I am using Niara theme and the product images disappear from both admin and front-end. The main issue was that the in admin Preferences / Images/ Regenerate thumbnails nothing happens when press Regenerate. I am using jpeg images for now, I haven't changed to webp yet as I am not sure if Niara supported. Actually I want to move to a higher version, is just that I have issues with my development environment and for now I can do things only in production which is stressful. Apologise if I was to pushy. Link to comment Share on other sites More sharing options...
the.rampage.rado Posted August 18 Share Posted August 18 When you updated the file format was probably emtpy: You will have to select one of them (they are all supported by Niara (recent versions of the theme)). Then save. Then you will have to reset your indexation status for all types and regenerate all types: Clear cache and check if they show up on both places. Link to comment Share on other sites More sharing options...
datakick Posted August 19 Share Posted August 19 20 hours ago, netamismb said: I upgrade to bleeding edge and it looks like the issue with issues with product duplicates is fixed, but now I have another huge issue, all the images disappears and the Regenerate thumbnails doesn't work. I mean, in admin Preferences / Images/ Regenerate thumbnails nothing happens when press Regenerate. I believe this will be a rewrite issue. The friendly-url links for product images changed, it used to look like /35-home/friendly-rewrite.jpg but now it contains /products/ prefix: /products/35-home/friendly-rewrite.jpg. You should regenerate .htaccess (or your nginx configuration if you are not running on apache). I believe this would fix the issue. If not, we could troubleshoot more. 20 hours ago, netamismb said: In the meantime I restore the backup. That's unfortunate, since we can't figure out what the root cause was now. Please test updates on dev/test site Link to comment Share on other sites More sharing options...
netamismb Posted August 19 Author Share Posted August 19 4 hours ago, datakick said: Please test updates on dev/test site I am working to fix my dev server and tested there, will get back to this thread when I manage to test it. Thank you so much for help. Link to comment Share on other sites More sharing options...
netamismb Posted August 20 Author Share Posted August 20 On 8/19/2024 at 9:41 AM, datakick said: The friendly-url links for product images changed, it used to look like /35-home/friendly-rewrite.jpg but now it contains /products/ prefix: /products/35-home/friendly-rewrite.jpg. The image link change is quite bad for SEO and for Google merchant, is it mandatory to contain the product, or is something that can be customise? Link to comment Share on other sites More sharing options...
datakick Posted August 20 Share Posted August 20 2 minutes ago, netamismb said: The image link change is quite bad for SEO and for Google merchant, is it mandatory to contain the product, or is something that can be customise? Why would it be bad for SEO? The original image urls still works, and google will (over time) learn about the new urls. Link to comment Share on other sites More sharing options...
the.rampage.rado Posted August 20 Share Posted August 20 42 minutes ago, netamismb said: The image link change is quite bad for SEO and for Google merchant, is it mandatory to contain the product, or is something that can be customise? I updated almost 1 month ago and I see no difference in the sales. I see an increase but this is not because of this change, this it is offseason for me. Domain authority is much more important. Even if you change your product URLs those will get fixed really quickly in google's index if your domain has good authority. For images - do you have statistics how much visitors you get directly from image search? Link to comment Share on other sites More sharing options...
