Can't standard attribute combinations be used?
The solution devised by Prestashop and adopted by Thirtybees is completely unsuitable for a large number of combinations. However, a few or a dozen attribute combinations can be handled.
@Alex Hansen It should be noted that all integrations and modules operate on standard attribute combinations.
If you use a non-standard solution, it will not be compatible with anything.
21 hours ago, the.rampage.rado said:
Could you describe your process/idea?
Well, think of a teamset for soccer, here we need sizes, colors and a lot more. When I create all this and click on combinations the system create to many combinations - So the system makes an error.
That's the reason I think of there is a better way to do this?
Currently, there is nothing better in thirty bees.
Soon there will be packs with combinations feature. You will be able to create packs where customers will be able to select colors, etc. But you hit another snag - sizing will have to be arranged manually with the merchant as currently there is no option to select 5xS, 5xM, 5xL in a 15x pack.
How many colors, sizes do you have? I have products with 11 colors and 10 sizes. If you combine personalization in the attributes, you're doing it wrong.
I see that someone else has also struggling with combinations. I haven't found anything better. Just need to think what You put in combination choice. I'm using also CSV import, without this is very very hard to manage combinations.
I our local PS FB group, we had a lady merchant who was selling custom wedding lapel pins and other stuff. Her combinations per product were around 30k I think (5-6 dropdowns with many choices per dropdown). Of course, the system would fold... 😄
I miss possibility that if superior combination limiter is set then in lower impossible options are inactive. At the moment You can make all combinations and system gives to seller only message "This combination is not allowed" (or something similar).
