Silver member
  1. Great 😎 While it sounds like it, IMO that's not really true. I have added to the AuthController now, which took me 30 seconds and it seems to work: https://github.com/eschiendorfer/genzo_turnstile/blob/master/genzo_turnstile.php#L167-L173 In general this approach is so simple, that I am not sure, if we really need a new sepecific hook. Actually that hook would be tied very closely ☺️ If you have a few free minutes, maybe you can evaluate, if nocaptcharecaptcha module would work with my approach to. I personally will switch to cloudflare... @ukclearance My module is open source: https://github.com/eschiendorfer/genzo_turnstile/. Only thing missing is actually the settings on which controller you want to use the captcha. The rest is working for me. Maybe you can check it out!?
  2. This is aksing for a lot of trouble. Spacing in webfolders is never a good idea... Just go for "niaragel"... or "niara-gel" is probably also working.
  3. Do you know that this project is dead tomorrow, if datakicks or smile "have enough"? Your behaviour is very disrespectful and without any reason. Datakick does merge a huge amount of PR in a fast manner. You seem to have no idea, what it means to lead this project...
  4. I wouldn't conclude that. I don't think a lot of merchants are using this at login.
  5. I coded in the night and it looks promising. I believe, that I found a solution for contact form, that needs no override and no file changes at all. Is there any need for something else than contact form? But I am little confused, how complex the ps-module and the nocaptcharecaptcha are working. @datakick My approach is like this: Register hookActionFrontControllerSetMedia (Hint: I am missing a hook like actionFrontControllerInit) Check if controller is instanceOf ContactController If yes, check if Tools::isSubmit('submitMessage') is true If yes, validate captcha If NOT valide I just unset($_POST[$submitToCheck]); Looks quite simple to me. Do you see any problem with it?
  6. Interesting! I will look into it, cause I also don't like google too much anymore. I will try to get rid off all their tools (which have direct access on my site)...
  7. This is no big problem IMO. You just have to divide original_wholesale_price/o.conversion_rate and not the sum. First taking the sum is even mathematically wrong, isnt it!? πŸ˜… I mean there is not a single static conversion_rate. It changes every day πŸ€” We are on the same page 😎 I will update my PR.
  8. PR is out https://github.com/thirtybees/thirtybees/pull/1598 😎
  9. Yeah I understand your point. I am personally just not a fan of mixed currencies in the same table, that are not marked by name or so. But ok it's not so an important thing. More important is to fix the bug, which is really there...
  10. This makes sense imo. Also PS has this approach, but lacked of consistency. @datakick If I see it correctly, the columns "purchase_supplier_price" and "original_wholesale_price" are stored in shops default currency. The other numbers in orders currency. My proposal would be, that we use for all numbers order currency. As we have the conversion rate, we can simply calculate them back. What do you think? This is actually what most devs would expect. They surely don't always recheck which column is in which currency. Ok I admit, that these columns probably weren't used a lot ^^ If you agre, I would make a PR.
  11. To me it's also questionable in which currency all the numbers of an order (ps_orders and ps_order_detail table) are (or should be) saved. @datakick do you know that? Are they ALL saved in the currency that the customer used? Are they ALL saved in the default currency? Or is there a mixture? Only this understanding would allow a serious usage of these numbers. After testing a bit, I think most values are in currency, which the customer chosed. But not all. That's why it's no surprise that devs use it wrongly.
  12. Nobody? Looking deeper into all these numbers, I have to say: PS did a solid job in saving the numbers. But a horrible job calaculation/accounting. There are a lot of places, where the system is just doing dubious things. Best example is statsordersprofit... If you have a simple setup without multiple currencies, it might be solid. If your shop has multiple currencies (suppliers) and a lot of price changes (suppliers) it's useless. But I can't fix this without other merchants, supplying me with their data.
  13. I am not totally sure. Maybe it works to create an override.js file and add the whole function. Then make sure that override.js is loaded after tools.js. It might work, but I really haven't used this before. Let me know πŸ€—
  14. Looking a bit into earnings I checked out order_detail table. In my case, it seems that the column purchase_supplier_price is always calculated wrongly. This column should show the price, you need to pay if you reorder the product at the supplier. The currency is your default currency. That's where my issue comes from instead of $price/$currencyRate it does $price*currencyRate... Can you please check, if it's the same in yours? (only relevant when you set up supplier price in a different currency) It's also helpful, if you show me a screenshot of your currency rates:
  15. @Beeta This things are quite tricky. Are you an experienced dev? I don't know exactly, what you are trying to achieve. But if it's only about "involic prestabay". It could be easier to modify this module a very little. You could set up a little cronjob and search for new/modified products by date_add or date_upd. Then you trigger the module "involvic prestabay" hook function (but not the hook itself).
  16. I don't know him personally and haven't used his version. But he is an experienced PS Dev and seems to invest a lot of time. So we would surely benefit, if he joins our community (and I guess he would benefit too).
  17. PR are out: https://github.com/thirtybees/thirtybees/pull/1582 https://github.com/thirtybees/niara/pull/65 At the moment only the password confirmation handling was changed in Niara. The birthday is still handled the old way. The deletion apply was not implemented yet, as I am not sure, if it's really wanted.
  18. No other opinions on this topic?
  19. Oh yeah this makes sense πŸ™‚
  20. I would do the same ^^ The module above is crap?
  21. It would be easy to add another configuration switch, but I dont like this idea as the BO is already now bloated with configurations. Somehow we need a proper form handler that allows required/optional setting for each field and allows to add custom fields. Obviously that's a huge and complex task, that won't come soon. I would recommend you, to just use CSS and hide the birthday field πŸ™‚ Thought that too. But also thought, if somebody goes on your computer, while you are logged in... That's why I want to secure password change, email change and account deletion. The rest isnt too critical imo. Saving payment infos on tb is crazy imo, I would never do it. Yeah I thought so, that this feature could even be a must in some countries. In general I don't think that all GDPR settings should be in core. Actually there is a module, but maybe it was never finished (?) https://github.com/thirtybees/tbgdpr. I don't need GDPR and don't know the rules, that's why I won't work on this deeply. How are you handling it now?
  22. Hello This is community-theme right? I was just looking into the code. Doesn't look buggy to me, as the other default theme (Niara) uses the same code. Are you using multiple languages?
  23. @datakick Thanks a lot! I did a full reset of the module and INSERTED it afterwards πŸ™‚ This time I was even smart enough to change the PREFIX 🀣 Will this entry be added automatically on upcoming version? I assume that this is a general problem with smarty, as all kind of module folders throw this warnings.
  24. Right now I am cleaning up the identity controller (when customer changes his profile in frontOffice) a little bit. IMO it was done a bit untidy. For my store I will also change the behaviour a little. I wondered, if it's wanted in the core to: Using date field type for birthday instead of three selects (dd-mm-yyyy). Now customer are forced to type their password each time, they change their profile. I want to make this restriction only, if he changes his password or eail. Why? At registration we have optional fields like birthday. Later I hope a customer would complete their profile, but obviously don't want to force them to type their password. As an user I hate such tasks. My brain says: ok sorry, then no birthday. I will implement an account deletion apply function. Important: it's an apply. A merchant will be notified somehow about it and then he can handle it. Of course this will also require the user to type his current password. This could also be implemented by a module, but IMO this functionality is kind of a core thing (at least much more than other things being on core). Opinions?
  25. Noted! I also thought, that in my process I would have to go on both BO pages, which is not so nice. But I have to think about the best implementation to fix this. Other feedbacks are still welcome! πŸ™‚
Γ—
Γ—
