led24ee
Gold member
Everything posted by led24ee
  1. Well... If there are subcategorys, then these are in different color and this is the same as background. So there is nothing visible. Also these aren't active. So if You click on these empty (actually they're not empty, address is visible on web browser, I use FF and this is visible bottom left corner) then nothing happens. Is this how it must be ? About menu depth. You can set this and it works, but result is total mess. Menu will be show all subcategorys too, but they are overlapping each other.
  2. Can anyone understand how "zentopmenu" module works ?
  3. There was the same problem and I turned on option "show review if there isn't any" and this creates review on every page. And the problem disappears. I hope there is someone who can answer much better.
  4. led24ee
    Images
    Well, client need picture, even if this is the same as for other product. In my example there is LED strip connection to power supply. This is drawing. Or You suggest that these pictures which are repeating can put in description. Then there is only one location for picture and no need to make ps_image every time ?
  5. led24ee
    Images
    About 11 000 products. Some products have 5 pictures. So there will be more than half million pictures(I mean ps_image). With combinations TB can show "right" picture, choosen from all ps_images (You can choose image for every combination. From all pictures for this product) . For example with different color. Or different end caps for profile. I'm not sure this will work with modified product.tpl.
  6. led24ee
    Images
    My plan was exactly "bound" one image with multiple products. So I have less images, but table in database is growing. So far this is idea only. An thanks to datakick explanation this idea reamins idea. So is there any way to put pictures in another server and tell TB where pictures are ? Plan B is very "original", just buy more inodes.
  7. led24ee
    Images
    Well. Then it is only way to manually put these in database. Of course this is mother of all fcukups ... But I have only something like half million files only for pictures and I'm running out of inodes.
  8. led24ee
    Images
    I have problem with images. If there are many products and they use the same picture then TB makes pictures for every product. But if there isn't difference then why ? Is there any way to use the same generated pictures for many product ? Products are created by CSV import.
  9. Install or activate some module for review and set this so that it is visible also when there isn't any review yet. In this case there is filed review and so far this is enough.
  10. I had to made changes in settings.inc to get these new modules. Without these there was no possibility to send emails. Previous version was 1.4 bleeding edge
  11. Thanks.
  12. With customization You can add text or picture (or both). The problem mentioned before appears on every case.
  13. I see there is fix aleady. I haven't tried it yet, but does this fix the same problem with attached picture also ?
  14. TB1.4 & PHP8.1 If there is possibility to customize product and You add something in text fleld then You can't delete this product from cart. The result is ERROR500, both BE and FE. If You look in database (cart_product) then this cart exist, but quantity is 0. If you change quantity at least 1 then everything seems ok and customization is also gone. Can someone confirm this ?
  15. Unfortunately I have idea. This is not easy (maybe real PITA) with 10 000+ products (description, pictures, features, etc) Almost 7 years of presta/thirty is more or less pointless. I have no idea how many modules/features/some other thing I need to pay again. And yes with new platform there are new questions and probably I discover that there are also lot of mistakes on new platform. About this language problem. According to Smile there is simple typo and f this is so then it will take about 1 minut to resolve and maybe 15 minutes to check, but looks like even this is too much. But Thank You anyway, maybe I find out that there is no other good place and I will return. So I hope no hard feelings.
  16. When some thing are working why there is constant need to "improve" this ? I'm trying to find another platform. Thank You.
  17. And this will stay so ? And this example is BS. Every value has its own ID. In previous version these were taken by ID. So when there already is value then this same value will be used next time, instead of creating new value. And yes, I just look in previous database and in current database. So whatever You are invented this is taking affect in current (TB1.4) version. Beside, there is still language problems. A year ago Smile says that he knows about this. And now what a surprise, this is still present. I can't understand why I donate this project. But at least I can solve this donation problem. Also I have offered translation package many times. Zero interest. So keep wondering why there isn't more people in this project.
  18. It is about BO - Catalog - Product Features. Some pictures added.
  19. Can someone explain this to me ? I have TB 1.4 and now this whole page of features looks like big piece of shit. I use CSV file to import products. And there are many products with same value. But in feature drop down list these values are all listed as different values. So there is list with 50+ values that are exactly the same. And actually different values are only 2. Why is this ? Or what I'm doing wrong ? There wasn't such problem with previous versions. Or is there any "manual" or something about this ?
  20. It is on my testsite. And so far I found out that cisero is somehow not connected/not having correct info from module "Advanced EU Compliance." With this module enable there is "Before" without this module there is nothing but only price per unit with no explanation, what this price is.
  21. Maybe it is already explained but what is this "Before" on product page ?
  22. led24ee
    CSV import
    There's still problem (this is from beginning) that pictures in different language need also different explanation. And this can't be done with CSV. In CSV file You can give picture and also description for picture in one language. Then You import another CSV which contains these same products, but for another language. But with picture You can't add different language for existing picture. This must be done some other way. I'm pretty sure (not tested yet) but the same is also with quantity.
  23. led24ee
    CSV import
    This sample file is wrong. With older version like TB1.1 it is working.
  24. led24ee
    CSV import
    Is there someone who understand this thing in TB1.4 ? This was working in TB1.0.x But in TB1.4 product import is working, but with combination this is fucked up. I spend whole day to find out that columns in TB1.4 sample file and actual import are different and You can't make working csv for product combination. Are there some changes that are not documented or is this some error ?
  25. Is there any plan to add slider option to this filter ? In PS forums user are "crying" about this more than 10 years. Problem is that values in database are stored as text (except price, weight which are automatically stored as number and slider option is hard coded for these). So it is pretty much pointless to put slider. Solution can be when values are stored numbers. But this lead to database changes and this is mostly source for all kind of problems. In other hand, if You can't store values as numbers then there is no need for a slider also. So there can be some kind check which tells You, can You use values for slider or not. Another way is create another table where values are stored as numbers. This again lead to way when installing this module there is also "converter" which creates values to this extra table. An then there will be many extra tables, depends how many slider filter are needed. Or maybe there are some other solutions ? Anyway, I still need this. Is there anybody who can make solution ?
