if ($SERVER['QUERYSTRING'] == 'profile') {
define('PSDEBUGPROFILING', true);
}else{
define('PSDEBUGPROFILING', false);
in my defines.inc.php but when I replace the coresponding lines in the file I can't install modules. It gives 'this functionality has been disabled'. I would like to use this function that way instead of the BO option because it quicker and more convenient.
the.rampage.rado
I want to use this:
```php/* Debug only / if ($_SERVER['QUERY_STRING'] == 'error') { define('_PS_MODE_DEV_', true); }else{ define('_PS_MODE_DEV_', false); } / Compatibility warning */ define('_PS_DISPLAY_COMPATIBILITY_WARNING_', false); if (_PS_MODE_DEV_ === true) { @ini_set('display_errors', 'on'); @error_reporting(E_ALL | E_STRICT); define('_PS_DEBUG_SQL_', true); } else { @ini_set('display_errors', 'off');
if ($SERVER['QUERYSTRING'] == 'profile') { define('PSDEBUGPROFILING', true); }else{
define('PSDEBUGPROFILING', false); } ``` in my defines.inc.php but when I replace the coresponding lines in the file I can't install modules. It gives 'this functionality has been disabled'. I would like to use this function that way instead of the BO option because it quicker and more convenient.
11 answers to this question
