Hello everybody,
I already made a post of this problem in german but now I'll try to describe it in english too, to hopefully get fast help.
I changed my webserver by doing the following stepps:
- packed data to zip on the old webserver and downloaded them
- uploaded zip to the new webserver and unziped them
- deleted .htaccess and smarty cache data
- exported database from old webserver and imported it on the new webserver
- changed access data in config/settings.inc.php (domain didn't change)
befor I was looking into the shopping cart all feeled good. Everything worked and the shop went much faster. After loading the shopping cart I first got the following errors: JSMin: Unterminated String at byte 3148: " JSMin: Unterminated String at byte 3164: " JSMin: Unterminated String at byte 3180: "
After doing a normal login I got this error:
Normaly after loging in and klicking on the checkbox for the terms of service, my PayPal Plus modul was loading. Not this time. I was checking and unchecking the checkbox without any reaction of the site. After reloading the site or getting to other sites and come back the checkbox is still checked. (Not sure if it should be like this)
I put all CCC settings off and these problem disapeard. On my old webserver I had the same CCC settings without problems. Don't know why I have to switch them off now. Now the PayPal Plus modul loading but only the button to make an order. It's not loading the different payment possibilities. I use the PayPal Plus modul from terracode. It's a Prestashop modul but it worked fine until now. So my plan was to activate the TB PayPal modul but the problem was even bigger! When trying to go into the shopping cart I get this error page loaded:
I was looking all the night for a solution but I found none. CCC is not working, PayPal modules are not working, my shop is not usable! It realy makes me crazy! I hope someone has an idea how to solve these problems.
Here is what I already tryed:
- generate new .htaccess
- checking access data for PayPal module
- changed from php 7.2.16 to php 7.1.27 on my new webserver
- made a second transfer of TB from my old webserver to the new webserver
- changed the domain from schmuck-checker.de to www.schmuck-checker.de and back
- put the authorization to 664 for files and 755 for folders
- tryed all type of combinations from performance settings
Batman
Hello everybody,
I realy hope someone has a solution for me.
Best regards, Robin
16 answers to this question
