Binder Posted March 31, 2019 Posted March 31, 2019 Good day all Please advise on how to trace what is causing the below error on my site when uploading csv? Csv import gives “Errors occurred: error” when trying to upload using ID, Stock QTY and Price. Sometimes I will receive the error at 3% uploaded then when I try again with the same csv I will get the error at 15% or 85%. The csv uploads correctly on my other site so there is nothing wrong with the file. I’m using the below PHP settings and also tried higher settings. max_execution_time=6000 max_file_uploads=50 max_input_time=10000 max_input_vars =10000 memory_limit=1G output_buffering=4096 post_max_size=256M session.gc_maxlifetime=1440 upload_max_filesize=128M I'm using thirtybees 1.0.8 I have also tried importing with below changes. Template compilation set to: Never recompile template files Disabled all non thirtybees modules and overrides Set all of the below settings to NO Smart cache for CSS Smart cache for JavaScript Compress inline JavaScript in HTML Move JavaScript to the end Apache optimization Keep JS and CSS files
AndyC Posted April 6, 2019 Posted April 6, 2019 I too had issues (Still do lol) ..I found this free module that is working a treat ... Only done a few items as a test , but what I did import worked first time https://oavea.com/free-prestashop-modules/2-export-products-free-prestashop-module.html
datakick Posted April 6, 2019 Posted April 6, 2019 @Binder are there any error messages listed in /logs directory (located in thirtybees root) ?
Binder Posted April 8, 2019 Author Posted April 8, 2019 On 4/6/2019 at 1:44 PM, datakick said: @Binder are there any error messages listed in /logs directory (located in thirtybees root) ? I did activate debug mode but there are no log files available under the logs directory.
Jonny Posted April 9, 2019 Posted April 9, 2019 I guess that's a time-out error 1. Enable the "Skip thumbnails regeneration" option, because generating thumbnails would cost a lot of time, you can generate thumbnails later. 2. Split your csv files to small ones, like 10 products per file.
Binder Posted April 9, 2019 Author Posted April 9, 2019 1 hour ago, Jonny said: I guess that's a time-out error 1. Enable the "Skip thumbnails regeneration" option, because generating thumbnails would cost a lot of time, you can generate thumbnails later. 2. Split your csv files to small ones, like 10 products per file. I'm only importing ID, Stock QTY and Price with "Skip thumbnails regeneration" Enabled. I'm not uploading new product, just updating prices and stock. Updating 10+ products is not an option as I need to update 25000 products daily. The csv file i'm using uploaded without any errors on my other website so this must be a server or website problem. I have also tried different hosting and PHP settings as per above post.
M5150 Posted April 9, 2019 Posted April 9, 2019 I struggled to upload csv files and found this in the forum @hedgehog that's definitely enough memory. So the culprit must be somewhere else. Could you please try to modify this line in classes/Tools.php and change it to look like this: 'verify' => _PS_TOOL_DIR_.'cacert.pem',https://forum.thirtybees.com/topic/2380-2380/csv-product-import-error-copying-image/?page=0#comment-23653 after changing it i could upload csv file .you might have to regenerate images .
Binder Posted April 11, 2019 Author Posted April 11, 2019 (edited) On 4/9/2019 at 6:04 PM, M5150 said: I struggled to upload csv files and found this in the forum @hedgehog that's definitely enough memory. So the culprit must be somewhere else. Could you please try to modify this line in classes/Tools.php and change it to look like this: 'verify' => _PS_TOOL_DIR_.'cacert.pem',https://forum.thirtybees.com/topic/2380-2380/csv-product-import-error-copying-image/?page=0#comment-23653 after changing it i could upload csv file .you might have to regenerate images . Just checked, I see I have already tried that:( Edited April 11, 2019 by Binder
M5150 Posted May 8, 2019 Posted May 8, 2019 Try this i had a problem with uploading csv files .When uploading look at you're csv file that there are no incomplete data left behind ,delete them . should upload .use open office .convert to ods. format.
