jmeca Posted September 18, 2019 Posted September 18, 2019 (edited) Hello I have problems with the template because in opc or instant checkout the Procced Chekout button does not work. I fill in the data and it doesn't go on, any idea? please I have tb 1.1.0 and Spanish and English language and neither works well https://expomueble.es Edited September 18, 2019 by jmeca
SLiCK_303 Posted September 18, 2019 Posted September 18, 2019 (edited) what theme do you use? edit: nevermind, following the link, it's Niara. Edited September 18, 2019 by SLiCK_303
the.rampage.rado Posted September 18, 2019 Posted September 18, 2019 What do you mean by 'the button does not work'? Also if the shop can be configured to use 1 step checkout so we can test it would help.
jmeca Posted September 22, 2019 Author Posted September 22, 2019 (edited) On 9/18/2019 at 10:19 PM, the.rampage.rado said: What do you mean by 'the button does not work'? Also if the shop can be configured to use 1 step checkout so we can test it would help. Hello, thank you for contacting, this only happens in Instant Checkout, when you enter all the data and you reach the final button "proceed to checkout" and you give the button does nothing, does not advance to the next step of the order you can see it in the following link: https://luzmayor.com/en/autenticacion?back=https%3A%2F%2Fluzmayor.com%2Fcarrito%3Fstep%3D1&display_guest_checkout=1 In the standard order 5 steps and one page chekout works correctly only fails in instant order Thank you very much for your help Edited September 22, 2019 by jmeca
James1 Posted October 18, 2019 Posted October 18, 2019 You have to agree to the terms and conditions, is that set? With the Niara theme the check box sometimes fails to display (even though you can plainly see it in the source code!) and without checking the check box you cannot continue. You can "fool" the browser by clicking just in front of the "I" at the start of the sentence and then magically the payment options appear but again clicking on that doesn't always result in activating the payment option unless you uncheck and check again the terms and conditions acceptance box when it will magically work the payment hyperlink again! Not sure if it is a browser issue or website issue but don't get these problems using the community theme.
veganline Posted October 19, 2019 Posted October 19, 2019 ...which turns off on the backoffice>preferences>orders page. (I expect everyone knows that but mention it just in case.)
jmeca Posted October 24, 2019 Author Posted October 24, 2019 Can anyone help, problems in Niara theme, quick order: An invalid form control with name='id_state_invoice' is not focusable. autenticacion?back=https%3A%2F%2Fventaregalo.com%2Fcarrito%3Fstep%3D1&display_guest_checkout=1:1 An invalid form control with
datakick Posted October 25, 2019 Posted October 25, 2019 Apply following fix: https://github.com/thirtybees/niara/commit/b9719ea0cfbc96fb3be9d0cfd803f7b3a90633e7 Or download file js/tools/statesManagement.js
jmeca Posted October 25, 2019 Author Posted October 25, 2019 Thank you very much for yur help Petr it work perfectly now
